Author Topic: Razer Saws  (Read 10772 times)
Martin13
Razer Saws
« on: June 20, 2008, 10:42:08 pm »
I have been looking at purchasing a Razer Saw but then noted that their are Ultra Thin and Flush cuttings Saws with TPI ranging from 32 to 52.
Are these saws suitable for cutting Plasticard Strip or say 1mm to 2mm Plywood? Are they of any use on thin balsa sheet to achieve a clean cut on end grain.
Can I please have your opinion on the saw that you have used and for what purpose.
All advice and opinions greatfully appreciated O0
Martin doon under
Re: Razer Saws
« Reply #1 on: June 20, 2008, 10:47:57 pm »
Yes, use them all the time. Handy tools. Some have a deep blade than others and with the strong back limits the depth of cut. Go slower on styrene than wood. Buy one and try it first. Med to fine rather than coarse toothed.
Bob Ferguson, NZ
HS93 (RIP)
  • I cannot spell , tough
Re: Razer Saws
« Reply #2 on: June 20, 2008, 11:01:42 pm »
good for balsa as said,  but also good for Brass  C+S type tube rod etc blade last longer than you would think , in fact I have not had to bin one yet, and I order  a few spare in case  :-X
Hs93
Re: Razer Saws
« Reply #3 on: June 20, 2008, 11:33:12 pm »
But be aware that a lot of these razor saws cut on the push stroke, not the pull.
Martin13
Re: Razer Saws
« Reply #4 on: June 20, 2008, 11:47:04 pm »
I didn't know that :embarrassed:
Martin
Re: Razer Saws
« Reply #5 on: June 20, 2008, 11:48:02 pm »
ok then Bob how the heck do you tell the difference
Re: Razer Saws
« Reply #6 on: June 20, 2008, 11:52:35 pm »
try it on a little bit of scrap, just use the forward stroke, then again just using the backwards stroke.
Or closely look at the teeth, the triangulsr teeth cut on the angle nearest the vertical.
Both sets that I have, which came with a small mitre block cut this way.
boatmadman
Re: Razer Saws
« Reply #7 on: June 20, 2008, 11:58:37 pm »
I have used one for years, great little things.
Another way to determine which way they cut on, starting at the handle rub a finger gently (or else lose a finger) along the teeth, if its sharp it cuts on the pull stroke, if not, it cuts on the push stroke.
Re: Razer Saws
« Reply #8 on: June 20, 2008, 11:59:32 pm »
well blow me this explains a lot now where did I throw that saw,the replacement works fine!!!!!!!!!!!!!!
Martin13
Re: Razer Saws
« Reply #9 on: June 21, 2008, 12:15:45 am »
Does it make any difference to the finished cut being on the push or pull stroke :embarrassed:
My eye sight ain't what it use to be - on the 52 TPI saw, I couldn't even see the teeth >>:-(
Martin
Peter Fitness
Re: Razer Saws
« Reply #10 on: June 21, 2008, 01:19:11 am »
Martin, I have used a razor saw for more years than I can remember (although with my failing memory, that may not be all that long  :o) and find it invaluable. I have a selection of blades with different TPIs, and use them for cutting wood, including balsa, plastic, brass and aluminium. A small mitre box is also very useful, and I normally use mine when cutting with the razor saw.
Peter.
boatmadman
Re: Razer Saws
« Reply #11 on: June 21, 2008, 03:53:05 pm »
Here is a pic af a Zona sabre saw set I got today from Chronos.
The top and middle blades cut on the push stroke, the bottom on the pull stroke, I hope the pic is clear enough for all to see.
Robert Davies
Re: Razor Saws
« Reply #12 on: June 21, 2008, 04:30:13 pm »
Razor saws are wonderful things for use in converting plastic kits to rc. Choose a nice fine blade (high tpi?) to cut through a decking piece and firstly it's through quickly, and secondly the edge of cut is beautifully finished, needing almost no further prep, thirdly, razor saws remove very little material during the cutting, so in the example of the decking piece above, the pieces either side of the cut can often be used as a near invisible butt joint.
The limitation of razor saws is the depth of the blade below the top edge brace - that's the maximum depth of your cut, but with alittle lateral thinking that can often be overcome :)
-Rob
djrobbo
Re: Razer Saws
« Reply #13 on: June 21, 2008, 10:49:19 pm »
Hi guys.....an alternative to razor saws that i have found is a small dovetail saw version of a japanese pull saw..It has a very fine blade but is quite broad so you get a good depth of cut....also being a pull saw the blade is always under tension when cutting and not under compression as when pushing so less chance of skip or wander
           as they say ...it works for me !
                regards..bob.
Martin13
Re: Razer Saws
« Reply #14 on: June 21, 2008, 11:33:55 pm »
Hi guys.......also being a pull saw the blade is always under tension when cutting and not under compression as when pushing so less chance of skip or wander
                regards..bob.
Thanks for that bit of info - now it makes sense why its a pull saw.
Thankyou to the forum -  I will take your advice and purchase a few saws as they are not expensive and give a fine finish - well done lads
Martin doon under
Bargain Saws
« Reply #15 on: June 24, 2008, 01:48:48 pm »
Damien
Re: Razer Saws
« Reply #16 on: June 25, 2008, 03:33:23 am »
Richard that link is a dud :(
HS93 (RIP)
Re: Razer Saws
« Reply #17 on: June 25, 2008, 03:40:52 am »
Damien
This will work same place , just go to general modeling then tools etc, good bloke to deal with and cheap postage in uk cannot say what its like out to aus but he is not a bandit...
http://www.redbankmodels.com/
Hs93
Peter
Roger in France
Re: Razer Saws
« Reply #18 on: June 25, 2008, 06:06:56 am »
I also use a fine Dovetail Saw. It has a brass back and a deep blade (about 80mm x 200mm). a wodden, straight handle (a little like a needle file handle). There is not much set to the teeth which are very numerous and fine.
Roger in France.
Re: Razer Saws
« Reply #19 on: June 25, 2008, 08:08:07 am »
Martin13
Re: Razer Saws
« Reply #20 on: June 25, 2008, 09:42:00 am »
Redbank try again.    http://quantrum.co.uk/redbankmodels/maxx-razor-p-878.html     O0
That's it Dicky O0. One handle, interchangeable Blades - does not say how many TPI though :(
Martin
Re: Razer Saws
« Reply #21 on: June 25, 2008, 09:43:20 am »
Lots  O0
Martin13
Re: Razer Saws
« Reply #22 on: June 25, 2008, 09:44:55 am »
Lots  O0
Are you reading my mind again ::) ::)
Martin
Re: Razer Saws
« Reply #23 on: June 25, 2008, 11:30:10 am »
Martin try this.  http://www.expotools.com/
Martin13
Re: Razer Saws
« Reply #24 on: June 25, 2008, 11:58:16 am »
Oh Dicky, they use VAT to ship to Oz. Going to do some damage to Visa now... ::) don't tell swmbo :angel:
Thanks for info Richard. I'm surprised John hasn't made a comment ::) ::)
Martin doon under
