Author Topic: Is it possible to connect two motors to one speed controller  (Read 4010 times)
uboatbuilder
« on: August 05, 2006, 08:54:11 pm »
Has any one done it, and could you tell me how? Also is it possible to connect two battery packs to one speed controller? Any help will be appreciated.
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: Is it possible to connect two motors to one speed controller
« Reply #1 on: August 05, 2006, 09:23:55 pm »
If you have 2x 6v motors and a 6v battery, you will want to wire the 2 motors in parallel (+ve to +ve, -ve to -ve on the motor terminals). If you have 2 3v batteries you need to connect them in series (+ve to -ve) to make 6v. If you have 2 6 volt packs, you need to wire them in parallel to end up with a 6volt supply but twice the capacity.
uboatbuilder
« Reply #2 on: August 05, 2006, 09:30:34 pm »
Thanks, but what about two motors to one speed controller?
Mankster
  • Wheelerdealer
« Reply #3 on: August 05, 2006, 09:37:00 pm »
>If you have 2x 6v motors and a 6v battery, you will want to wire the 2 motors in parallel (+ve to +ve, -ve to -ve on the motor terminals< then hook up the ESC the normal way.
uboatbuilder
« Reply #4 on: August 05, 2006, 09:56:27 pm »
Thanks I think ive got it now
