Author Topic: Build yourself a rock band  (Read 4827 times)
« on: July 01, 2008, 11:31:42 am »
May be of special interest to PMK
http://nz.youtube.com/watch?v=HUUdFXwAYRs&NR=1
A new type of modelling perhaps ???
dreadnought72
Re: Build yourself a rock band
« Reply #1 on: July 01, 2008, 12:16:07 pm »
Stunning. My kind of music.  :D
towboatjoe
  • Rollin' on the River
    • Towboat Joe
« Reply #2 on: July 01, 2008, 12:36:30 pm »
Neat video. Now if only I could animate the band on my party barge.
bigford
« Reply #3 on: July 01, 2008, 03:46:33 pm »
some people  O0 {-) :D :o
 if i only knew more about computers
dreadnought72
« Reply #4 on: July 01, 2008, 03:48:18 pm »
Bigford, you're on here - what more does anyone need to know?!  O0
« Reply #5 on: July 01, 2008, 03:53:21 pm »
Actually towboatjoe, that is not hard.
Lots of antique kids toys and the old fairground carousels did this using cams or wheels and pushrods or wires. Even the little monkey banging the cybals and the dancing trumpet players. OK so you can see the rods, but that never bothered the Muppet show.
Getting it synch with music is harder, but we have all seen actors pretending to strum guitars in films (out of time), and at the scales you are using nobody would really notice.
towboatjoe
    • Towboat Joe
« Reply #6 on: July 01, 2008, 06:37:18 pm »
[/quote]
True, but the hard part is doing it in 1:48 scale. The party barge above is 1:87.
« Reply #7 on: July 02, 2008, 09:38:09 am »
Towboat, you could use the strands from 30amp wire, or co-axial TV cable core.
The motors from lego tech, or other slow turning motors could be used. You need about 30 rpm, and generate very small movements.
The joints of the little people could be articulated with a cloth hinge or piece of rubber. This is crude but a 1:87 it will not be that noticable. You will have to sacrifice something to achieve the movement.
I think I could do it, it would be a fiddle and a bit of a learning process, but the mechanics are simple and would scale down to .
When I finally get back to my workshop I will maybe have a go. But that will not be until October.
OMK
« Reply #8 on: July 02, 2008, 10:29:58 am »
"When I finally get back to my workshop I will maybe have a go. But that will not be until October."
I'm gonna hold you to that, because I for one would love to see how it turns out.
Going back to that YouTube vid', I think the man deserves a medal. Okay, okay, so maybe it looks a tad Heath Robinson and maybe a bit rough around the edges, but the idea is there. And there's no doubting the man's flair for the unusual.
Did you see all them solenoids there? They look similar to those found in washing machines, etc. Dead clever how he manages to sync them to the music... which, incidentally, is no easy feat. It must have taken him hours and hours to program each and every sequence.
Excellent video, Tiger.
(I can hardly wait for October to come around).
TowboatJoe, is there a chance you could up a few more photos of your party barge?
« Reply #9 on: July 02, 2008, 01:14:33 pm »
Hi PMK
Anychance you can help me out with a small  motor that turns at variable rate at around 30 rpm.
And if anyone can point me in the direction of some 1:87 scale figures. Cheap ones.
Towboatjoe, did you purchase your band as a set, if so where from? Or are they modified pieces?.
I would be much abliged.
« Reply #10 on: July 02, 2008, 01:29:17 pm »
towboatjoe
    • Towboat Joe
« Reply #11 on: July 02, 2008, 04:49:25 pm »
[/quote]
[/quote]
I modified all the figures and made all the instruments and sound equipment.
It's been sitting on a shelf for the past ten years. I quit working on it because I decided to build it in a bigger scale with sound tracks of the band I perform with.
Here's some closer photos of the band. The left handed bass player I made to look like me.
towboatjoe
    • Towboat Joe
« Reply #12 on: July 02, 2008, 04:57:05 pm »
Here's a layout drawing.
Now, let's find some more of those robo musicians on YouTube.
Has anyone seen james Taylor's drum machine made entirely from wood.
A cabinet maker friend helped him build it. It's a mechanical marvel.
OMK
« Reply #13 on: July 02, 2008, 09:39:45 pm »
Hi PMK
Any chance you can help me out with a small  motor that turns at variable rate at around 30 rpm.
Sure. But when you say small, how small? I got a few of these in the junkbox -- plenty of torque at low speed. They operate from around 3 volts up to 6 volts. Any good? (I used one in conjunction with some gubbins robbed from a defunct CD ROM while experimenting with deck lifts). No problem to cobble together a circuit to have them running at 30 RPM.
Lemme know what you think - I'll bung a couple your way.
(That there is a AAA-sized cell, by the way).
Nice pics, Towboat.
You say the bass player was made to look like yourself? In that case, is the name of your band ZZ Top?
Even the keyboard player has all his black and white keys in their proper place. Nice touch!
towboatjoe
    • Towboat Joe
« Reply #14 on: July 02, 2008, 11:38:57 pm »
The band I've been working wit hthe past couple of years is named KYOVA
The band looked a lot better, but years of sitting on the shelf has took it's toll. {-)
« Reply #15 on: July 03, 2008, 12:50:37 am »
Hi PMK
Those motors would be fine thanks :D
I have PMd you
FullLeatherJacket
« Reply #16 on: July 03, 2008, 08:21:51 am »
PMK
Just up the road from Dude Ranch is a place called Clevedon. A guy called Mike Mayhew operates from there, trading as Waverley Models. Apart from his stunning paddle steamers and boat renovations, animatronics is a specialty of his and he's one of the nicest blokes you'll ever meet. He'd cheerfully show you round his workshop and if you can help him out with a few ad-hoc electronicky bits then I know he'd really appreciate it. 01275 546772 should find him.
FLJ
OMK
« Reply #17 on: July 03, 2008, 01:00:51 pm »
What, you mean this chap?...
http://www.waverleymodels.co.uk/
Well I'll go to sea! He's only about 25'ish miles from here (as the crow flies).
Thanks for that. But this is Tiger's baby, so rather than go stepping on his toes I'll see what he has to say about it first before I go jumping in.
Mind you, I'm tempted to give the man a call anyway - just to have a chat and see what's what. Do you mind if I mention your name?... to let him know how I found out about him?
While we're on the subject of motors.......
Do you remember the other day when I pestered you for that piece on motor rewinds? Dig this...
I found out just last night, purely by accident, that your reply was there waiting for me all along, only I didn't realise it because somehow it had gone directly to the mailer's junk folder. (No, I don't know how it happened, either). For a spooky moment there I thought I might have said or done something to hack you off - wondered why I hadn't heard from you sooner.
ENNYway... Thanks a million for that. I got me a whole load of mag' wire. I'll let you know how I get on.
(It's gonna be my first ever motor rewind, so I'm treading new waters here).
Tiger:
Message received loud and clear.
I've just been called out for a job (all the way down Brixham, dammit). Not sure what time I'll be back, but keep an eye on your PMs.
(By the by, what do you think of those figures in the link that Richard suggested? Nice, eh?)
OMK
« Reply #18 on: July 03, 2008, 01:04:29 pm »
.......Nearly forgot.......
Towboat:
Thanks again for the pics (and the barge dimensions).
Some real nice ideas there - tt certainly is food for thought.
Later............
« Reply #19 on: July 03, 2008, 01:57:00 pm »
Hi PMK
If you want to got to see Mike Waverly and add to this thread, go for it.
I tried to visit him last time I was in UK but I missed him twice. I don't know If I can get down there next time.
I will watch my PMs.
« Reply #20 on: July 05, 2008, 09:37:10 am »
OMK
« Reply #21 on: July 05, 2008, 11:31:12 am »
Jeezus Kriced! Have you been sniffing Mary Jane again? What in hell's bells is that 'music'??! :o
That circuit board you wanted is all but ready to go. I even found a couple more motors, only these are a bit better (runs @ 1.5v to 3v with slightly more torque).
Tell your bro' to expect a package any day now.
Nearly forgot...
I tried calling Mike W. on the blower yesterday. No joy - the phone just rang and rang and rang and rang and rang and rang and.......
Panic ye not, though - I'll try again today.
Will keep you posted.
« Reply #22 on: July 05, 2008, 01:22:31 pm »
I know mike isn't always there to answer the phone.
His mobile number is now always ansered either.
OMK
« Reply #23 on: July 06, 2008, 05:24:02 pm »
FLJ was good enough to let me know that Mike is not in his shop on the weekends. It's Sunday and there's no way I'm going to pester him on his day off, so I'll try again on the morrow.
Here's your circuit board.
I intended to send you a wee sketch along with the package, but my printer is out of action. By the time you get here you might have forgotten what wire goes where, so you might want to save or print them off, for future reference.
I taken the liberty of stuffing a beefy FET in there. It means you can run at least few millions motors without anything breaking into a sweat. But if the motor runs opposite to what you want, reverse the yellow and blue. Don't reverse the red and black, else the chip may go blooie. There is no input polarity protection. On reflection, I should have stuck another diode there. There's plenty of room for one, but I didn't think to do it until AFTER I stuck the double-sided foam tape on the underside. So make sure you stuff the red up the positive.
Don't feel at all guilty if you get a sudden urge to send me 1 x pint of scrumpy.
« Reply #24 on: July 07, 2008, 11:42:13 am »
At HO scale, hand and arm movement might not be very noticeable from more than a couple of feet away, apart from the drummer.  Perhaps just oscillating the standing members to give the impression of looking out for the next incoming beer bottle?
Maybe control the motor from the music via a filter and level detector?
Page created in 0.097 seconds with 21 queries.
