hi there
with regard to bonding to a fibre glass hull using either polyester resin or epoxy resin - the area to be bonded on the hull must be firstly, roughed - up with either coarse emery or sand paper, breaking the fibres in the fibreglass layup - the reason for this is that the hull is what is know as past its green state - it is now cured. Any further laminations must be - what is known as 'mechanical' rather than 'chemical'.
Failing to abrade the area, you will find, after a period of time, the applied Epoxy or Polyester resin will possibly pull apart.
You say you have used P38 filler to bond in the propeller shaft - this is ample - there is no need to put a coating of any epoxy resin over thetop of this on the inside and normally, you would be painting the filler on the outside and therefore preventing any water impregnation. The only time I would worry about sealing fillers on the inside of the hull, is, if you know the inside of the hull is going to be constantly wet. Or, indeed, subject to glow/petrol fuels. The other thing is rather than pour Epoxy resin around your rudder tube where it enters the hull - cut a piece of one eighth plywood - say 1 1/2 inches square and sand it so it fits neatly to the shape of your hull. The epoxy this to your hull - and then drill through the plywood through the existing hole in the hull for your rudder tube. Doing it this way, is a far easier and better way to dissipate the stress on your hull.
Avoid pouring copious amounts of polyester or epoxy resins - into these areas. What happens on vast amounts of resin without matting added - and poured into the hull - it shrinks/expands at a far different rate to the actual hull itself. There delaminating itself.
That is how you always tell a bad fibre glass hull build - you will see where folk have added resin to either the bottom/side of the hull and it forms 'pools' - apart from being an utter waste of resin it actually does more harm than good.
A good fibre glass hull should have a matt appearance and when you rub your fingers over the hull, you should 'just' be able to feel the strands of glass. There should be no evidence of dry areas - e.g you will see the glass show up as white.
Hope this is of some help.
Aye
john e
bluebird
