Pages: [1] 2 3   Go Down
Author Topic: Steam engines in real ships....  (Read 22881 times)
« on: July 12, 2008, 02:25:12 pm »
Can I ask a stupid question (another one!)?
I presume the the big ships, ocean liners, battleships etc (and I suppose and all steam vessels) use
fresh water for the boilers..... therefore, in real ships, how do they carry enough water for the
boilers, engines, turbines?
Re: Steam engines in real ships....
« Reply #1 on: July 12, 2008, 02:37:52 pm »
hi there
To answer your question; basically, there is a condenser on board the life-size ships; this converts the exhaust steam back into water.   This is then returned to a holding tank to where the boiler takes its water supply from.   Obviously it is a lot more complicated than this, but, this is how it works.   I have included a scan from a book to try and explain.
aye
john e
bluebird
« Reply #2 on: July 12, 2008, 02:42:29 pm »
Not one you made earlier then John ?  ;)
boatmadman
« Reply #3 on: July 12, 2008, 03:14:29 pm »
Boilers dont use fresh water as we know it - from the taps. If they did, the heat exchange surfaces would scale up, reduce the heat exchange rate and ultimately fail.
One way is to uses de mineralised water, that is, all the salts have been removed by an ion exchange process, leaving the water extremely pure with a conductivity of well under 0.01 micro seimens. This pure water also tastes foul!
Another way is to use reverse osmosis units, these are basically an ultra fine filter that acheives the same result as ion exhange.
Clearly a ship cannot carry enough water to top up the steam/water cycle over a voyage - there are always losses and boiler blowdowns that remove water from the system.
Shipboard systems are designed to use sea water as the water source and purify it to boiuler quality.
On the ships I worked on, we used evaporators, under vacuum, boiliing the water and collecting the steam, condensing it and using it in the boilers. the problem with these was that the salt removed caked up the elements and and had to be cleaned on a regular basis.
The system Bluebird described is the basic system used in all steam/water cycles - ships, power stations etc.
Bunkerbarge
« Reply #4 on: July 13, 2008, 12:40:30 pm »
One of the biggest problems with flash evaporators over the years has been the build up of scale in the evaporating chambers but nowadays we dose chemicals which do an amazing job of preventing this scale from forming.
A couple of interesting points to add to the conversation, evaporators nowadays use "waste heat" to power them such as the cooling systems from the main engines and supported by steam generated in exhaust gas boilers, that's why they work under a partial vacuum, to enable boiling at a much lower temperature than at atmospheric pressure.  The evaporators not only produce pure distillate for feed but also go through mineralisers to produce potable water and typical cruise ships evaporators could be capable of producing 1000-1500 tons of water a day.
If the vessel is steaming slowly and not producing much waste heat then auxilliary boilers have to be used to support the evaporators.  Then the water produced instantly changes from becoming almost free to extreemly expensive.
As for the boiler feed the evaporated water is the best water you can use for feed as it has been distilled three times, however for high pressure boiler use, i.e. main propulsion this feed water would need to be of an even higher quality.
I always use distilled water in my model boilers, which everyone tells me is not necessary, but there is no doubt in my own mind that it is better for the long life and efficiency of the boiler.
Back to Martins first comments though it is interesting to compare modern practise with the very early coastal steamers.  They used raw sea water as feed and had to go into the boilers every few days to scrape the salt out.  This was usually in conjunction with scraping the furnace chamber out as well while the plant was still hot.
boatmadman
« Reply #5 on: July 13, 2008, 03:37:33 pm »
I would always advocate de mineralised water in model boilers as well.
The problems associated with poor quality water will arise in model boilers just as in full size. The only difference being in time scale - models get used a fraction of the time of full size ones.
« Reply #6 on: November 16, 2008, 03:24:02 am »
A respected colleague....Sandy Campbell from ACS once mentioned in the PD forum that de-mineralised water was OK with copper but   <:( should never be used with brass tubing as the fluid has the natural potential [through the electro chemical + - series] to leach the zinc component from the tubing substrate ....& hence over time reduce the actual wall thickness through micro porosity & resultant loss of strength in the tubing
As bunkerbarge notes above........the same as the recomendation from Sandy was......distilled water is the best option....... - Derek
PS..... nice to see many PD members also here  :-))
Bunkerbarge
« Reply #7 on: November 16, 2008, 11:02:13 am »
Hi Derek and welcome to Mayhem.  Yes there are a few PD's on here as well.
Someone recently gave an excellent description of the potential dangers of using de-ionised water in model boilers, which should really be avoided.  This is usually the water you buy in a car spares shop for battery use so read the label carefully.
I have actually started to use the water my missis throws away from our condensing tumble drier.  It is basically distilled and a plentifull supply for nothing.
« Reply #8 on: November 16, 2008, 03:06:47 pm »
Snap Bunkerbarge, thats where I get my water from, unending supply in our house.  :-))
Bernhard
« Reply #9 on: November 16, 2008, 03:31:29 pm »
hi..
i fund this
What is the difference between distilled and deionized water? Can I use deionized water in my boiler? Do not use deionized water in your boiler! Use only distilled water in your small-scale steam boiler. Your engine will run on deionized water or even ordinary tap water. But there are problems with each of these which we should avoid.
Tap water contains minerals which will stay behind when you boil the water out of the boiler. When you run your steam engine, you are in essence distilling the water in the boiler. What comes out the regulator is pure water vapor, and the minerals are left behind in your boiler as scale. When you use distilled water in the boiler, there is nothing left when you're finished.
Scale reduces the boiler's ability to transfer heat to the water, and thus reduces the efficiency of your engine. Eventually, the lines may become so clogged with scale that you can't get any steam out of the boiler at all. Operators of larger engines can sometimes remove the scale physically by scraping or brushing. We have no such small scrapers and brushes, though. Scale can sometimes be removed by boiling vinegar or some other very weak acid in the boiler. This should not be considered a desirable alternative to using distilled water, however. Stick with distilled water and you won't have to worry about mineral scale.
Deionized water contains no ions, which means it has had the chemically reactive molecules removed. If put into contact with metals, however, it will happily take on new ions, with disastrous results. Mike Chaney wrote about the effect of using deionized water at a UK exhibition:
After about a weeks running some of the loco boilers started to "weep", although they had been properly tested and certified. An investigation showed that the silver soldered joints were failing because the water was trying to grab back ions from any metal with which it came into contact. Copper, zinc and silver were found to be particularly susceptible.
Moral: for the long-term health of your boiler, avoid deionized water!
Bob Stiegler wrote
I bought two measuring devices at the local wholesale nursery supply co. One measures pH, the other total water hardness. I tried them out on collected rainwater, and measured 7.5 pH (neutral) and approx 5 ppm total hardness (verrrrrry soft). Not having the facilities for collecting large amounts of rainwater (and having no way to collect any rainwater whatsoever when its snowing), I bought some bottled water. It was also neutral and sufficiently soft, but expensive. I then saw something called an RO (reverse osmosis) watermaker in a tropical fish supply catalog. Not cheap ($200.00, approx), but very effective (7.5 pH, 1 ppm total hardness). It takes a couple of hours to fill a 7.5 gallon water bottle. My plants thrived, and I didn't go bankrupt buying soft neutral water.
While this is a bit too expensive to be justified by the the average small-scale live steamer, it's something which could be attractive for a club to buy as a group. Or, if you keep tropical plants or fish, you might well get enough use of it to justify one yourself.
« Reply #10 on: November 16, 2008, 06:43:18 pm »
I think the loco boys have to be a lot more careful than we do, as they tend to have lot longer running times. I have several boilers (scott-semi flash) that were built pre-war (WW2 as opposed to any other war we may have got involved in) and although I can't see inside, I still use them regularly and they are tested every 2 years to twice working pressure (around 220 psi) as if I'm going to test why bother with the 1 1/2 times, and they have both been using tap / pond water . Now when I add up total running time in a year it amounts to around 6 hrs. OK so its straight running, so running times are not as  high as say a radio steam boat, but I've not had any problems (so far), but then these days there are a lot more "things" in our water, so I tend to use the water from the tumble drier---after all, if it helps prolong the life another 60 odd years   :-))
craftysod
« Reply #11 on: November 17, 2008, 07:12:47 pm »
Not knowing very much about steam,i do know that full size steam vehicles need a boiler certificate.
Does that apply to models as well,as Steamboatphil mentioned above tested at 220psi,thats a lot of pressure.
Mark
« Reply #12 on: November 17, 2008, 07:36:25 pm »
Hi Craftysod, yes we do test our boilers as required by Model Power Boat Assocation rules and guidelines, I know that other clubs which may not be members of the Assoc also have boiler testing guidelines, its two fold, 1) it checks the boiler for any failings 2) a lot of public parks may insist on 3 rd party insurance, and boiler testing is usally a requirement of the insurance company. There is also a bar/litre chart which some clubs have adopted. In a nut shell, if your boiler contains a small amount of water (when full) and works on a low pressure you bo not require a boiler test (you x one by the other)
For testing, new boilers are tested to twice their working pressure, and then to 1 1/2 x every two years after, although I tend to test my own a little higher. Hope this all helps.
Phil
craftysod
« Reply #13 on: November 17, 2008, 07:45:23 pm »
Thanks for that,i get a little wiser everyday
Mark
Archibald H.
« Reply #14 on: November 18, 2008, 11:08:28 am »
Apparently demineralized and deionized water is the same thing:
http://en.wikipedia.org/wiki/Distilled_water
So if I understand correctly, it's destilled water which is okay to use?
Cheers, A!H.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #15 on: May 08, 2009, 11:23:05 pm »
Just to throw a spanner in this thread- up until condensing technology- after the freshwater tanks had been used up the boilers were fed with salt water- making salt stallactites on every leak in the engineroom!!! Not reccomended. :D
flashtwo
« Reply #16 on: May 09, 2009, 10:19:08 am »
Another thing bad for boilers was oxygen in the water.
When I was an apprentice, one of my tasks was to check the boiler hydrazine injector was at the correct flow rate. Yes, as we all know hydrazine is used as a rocket fuel, but it also scavenges up any oxygen in the water.
The station chemist, in those days, had a very good sideline in wine making (and brandy!) and one day asked me to find an empty hydrazine barrel, i.e. the thick steel one with the skull and cross-bones label on it. Enquiring as to its use, he said it was for the next batch of wine production!#$%!!!
Noting my total disbelief, he then gave me a quick chemistry lesson on how water breaks down hydrazine - oh what faith!.
Ian.
(I did test the wine on an uncle (he survived), who had been a wine waiter, and he thought it was a German Hock - perhaps it was still useful as rocket fuel!)
Steamer
« Reply #17 on: June 09, 2009, 06:11:51 am »
Very old vessels ran seawater in their boilers and if you google a "salinometer" you'll find out how they determined when to "blow down" the brine and refill with with "fresh" seawater.......Not the best thing for a boiler, but at 20 psig, it wasn't such a big deal.
In the modern era....1870's forward....and I speak to reciprocating engines only.
For ocean travel, ships used evaporators to create fresh water from sea water.
Boiler steam was run through coils in large tanks.  The water would boil off and be collected.   Periodically , the tanks would be opened and the salt cleared.
Of course these ships, at least the modern era, ran condensers...which also helped engine performance.   The steam was condensed and brought to a tank called a "hotwell".   This tank was used to dearate the condensed water brought there by the wet air pump and to remove any lubricating oils that might have been in the steam....A Wet air pump is an appropriate name as it took condensate and air out of the condenser.
Boiler water chemistry was and still is very important to the life and well being of a boiler.  This analysis was done by the "Chief" by performing various chemical analyses usually by titration reactions.   From there, The Ph , dissolved solids, and sulfates among other things could be determined and altered with various chemicals added to the feedwater usually in the hotwell.   Keeping the Ph slightly alkaline was ideal......now in small scale....starting out with distilled water is easier!
kiwimodeller
« Reply #18 on: June 09, 2009, 12:42:29 pm »
I had read the publicity about de-ionized water and was avoiding that but having trouble getting distilled water when another member told me that for many years he has just used tap water but that once a year he does a couple of boil-ups and flushes using a de-scaling chemical made for cleaning commercial water heaters and kettles. Is there anything wrong with doing this? Ian.
Bunkerbarge
« Reply #19 on: June 09, 2009, 01:23:01 pm »
Difficult to say right or wrong but for me I would rather avoid the build up in the first place.  As long as this is occurring the boiler is loosing it's ability to transfer heat and there is even a slight danger of a hot area occurring due to poor heat transfer.  I don't actually think it is an issue in a model boiler but I'd rather keep my plant in the best possible condition  rather than alow it to get dirty and then clean it.
As I said though no right or wrong, only personal preferences.
BarryM
« Reply #20 on: June 09, 2009, 01:52:59 pm »
It depends on where you live and thus the hardness of your tap water. Doon in the Deep, Deep, Sooth I recall kettles built up a thick layer of limescale. Not nice at all for boilers. However, this side of the Border, kettles very rarely show any kind of build up because the water is very soft and was often used (still is?) neat for topping-up car batteries without any obvious ill-effects.  Thus, I don't have a problem with using tap water but, if your soap is hard to lather, I wouldn't risk it.
Barry M
Inkmark
« Reply #21 on: June 09, 2009, 02:49:36 pm »
Hi Guys
When de-ionised water is used in a boiler it always has oxygen scavenger and, more importantly, a corrosion inhibitor added.
As previously posted de-inoised water will very rapidly attack metals because it doesn't like to be de-ionised,
it wants some mates to play with so goes looking for ions.
If you read your car manual most specify that de-ionised water must not be used 'cos it causes rapid corrosion.
Has anybody experimentedwith de-ionised water with car antifreeze added? since most are also corrosion inhibitors.
Mark
flashtwo
« Reply #22 on: June 09, 2009, 07:33:02 pm »
I do recall an apprentice (not me!) thinking it might be a good idea to use water from the boiler water treatment plant in his cars cooling system. Within days his radiator sprung leaks from numerous hard to repair joints - a lesson not to be forgotten.
Ian.
Steamer
« Reply #23 on: July 07, 2009, 04:12:48 am »
Actually did a bit of reading in my library on evaporators.  It would seem that the supply steam could come from the boiler or from one of the engine Intermediate  receivers.  This steam was run through the coils and then to the condensor.    The salt water side was run to the condensor or to the LP exhaust receiver.   It was important that the evaporators not be forced or left highly scaled as the salt would carry over into the fresh feed water.
BarryM
« Reply #24 on: July 12, 2009, 06:43:25 pm »
Dave,
Early vaps did use fairly high pressure steam but anything fron at least the '50s on used live steam at about 30psi max or a turbine bleed if the vessel was a turbine proppelled vessel. Motorships commonly use waste heat from the main engine CW or an exhaust boiler. The condensate from the heating element drained to the main condenser.
I'm not at all sure what you mean by the "salt water side was run to the condenser or the LP exhaust receiver etc...." - makes no sense to me. The SW feed was boiled off under a vacuum by the heating element, passed through a demister and subsequently condensed in the vaps own heat exchanger and then pumped to the feed tanks if the salinity of the output was low enough. If the salinity of the output was too high, it was dumped to bilge. The direction of output was controlled by a salinometer which continuously monitored the output and opened a dump valve if the salinity rose too high.
To keep the salinity of the boiling SW feed in the vap shell to a reasonable level, a proportion was continuously pumped out via a wier and brine pump to sea.
To try and keep scaling on the heating element to a reasonable level, the vap was shut down and the element 'cold shocked' daily. This involved heating the element with steam and then shutting off the steam and rapidly cooling it with a cold seawater spray in an attempt to crack-off the scale. It only worked to a point and eventually the element would have to be extracted (not the most favoured job) and soaked in a bath of 'Safacid' (spelling?) or similar. Even this was often only partially successful. While the element was out, that useful item found in most engine rooms and known as an Apprentice was introduced to the inside of the evaporator shell with a chipping hammer. There he would discover the delights of sitting in a pool of hot seawater on sharp fragments of scale while leaking steam valves dripped boiling hot water on him and, if he was unlucky, the lead lamp might drop in the water and smash; before - hopefully - the fuse or breaker shut off the current he could enjoy the thrill imparted by 110Volts. This was known as "Good Experience" and heartily endorsed by more senior engineers who believed in tradition.
Hope this helps,
Barry M
Pages: [1] 2 3   Go Up
