Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: My RC live steam tugboat / icebreaker  (Read 72553 times)
Re: My RC live steam tugboat / icebreaker
« Reply #125 on: November 12, 2010, 09:39:12 pm »
kno3......this vessel has had I think 3 x differing engine & boiler configurations  {-), but each one beautifully presented  :-))
KBIO....I am unsure of your comment .... "It will store the water, cool it down but due to its shape , this water may cause back pressure on the outlet of your engine"
Is it just the tangential inlet that concerns? ....& the swirling to 180 degrees only....? .... very interesting....Derek
KBIO
« Reply #126 on: November 12, 2010, 10:20:14 pm »
Sorry! I was completly out of the picture.   :embarrassed:
For any reason, I thought that KNO3's condenser was build to be installed , flat, underneath the boiler. %%
Now I saw it standing along side the vertical boiler and what i wrote previously is non sense.  {:-{ >>:-(
Thus, concerning the tangential entrance in a condenser (Cheddar type), I like it as it creates a cyclone wiith water condensing on the walls  and the steam stream escaping freely in the middle top.
Damned! I still have to step backward, learn to read and think twice before to say anything! Some (like me) will never learn. %)
Still, I go on admiring KNO3's tug! :-))
Regards :-)
« Reply #127 on: November 12, 2010, 11:20:16 pm »
Thats OK.... :embarrassed: ...KBIO...I also am guilty of typing first & asking later.......
kno3....one point you could consider.. O0 is insulating the exhaust steam line from the engine to the condenser........the basis for this is maintaining the highest possible steam temperature in the line & the resultant greatest cooling differential as the steam enters the non insulated condenser  %) ......Derek
PS1...I have not before seen the YELLOW  Regner rectangular body gas tank  %%
PS2...what has happened to that beautiful  :kiss: :kiss: :kiss: Winfried Niggle quartz lens bodied lubricator?
rathikrishna
« Reply #128 on: November 13, 2010, 06:38:29 am »
thank you..respected friend...
kno3
« Reply #129 on: November 13, 2010, 08:58:27 am »
I'm not convinced that insulating the steam line to the condenser would bring much, but it should help me not get my fingers burned if I accidentally touch it  :-)
Regarding the gas tank, look it up in the Regner catalogue at page 53: http://www.regner-dampftechnik.de/online_katalog/index.html
The Niggel lubricator is still part of the other steam plant, which is patiently waiting for a new boat:
2009-10-14 003 by -kno3-, on Flickr
Bunkerbarge
« Reply #130 on: November 13, 2010, 10:09:48 am »
I personally think it is a good idea to lag the exhaust steam line.  At this point the steam is ready to convert back to water and the slightest reduction in temperature will help this.  After going through the seperator to try to remove the water then letting the temperature drop is defeating object a bit.  I would defenately lag the pipe, and, as you say, it's one less to burn your fingers on.
« Reply #131 on: November 15, 2010, 09:46:02 am »
Hi knor3.....from your .jpgs below it is clear that the Regier gas tank as installed cannot be easily remover for refilling  {:-{
We see a different type of refilling valve [over the bogstandard Ronson type]....[no offence to John Moore  <*<] .....
Is there an advantage in the filling procedure?..is it a non leak varient? :o  .....Derek
kno3
« Reply #132 on: November 15, 2010, 10:51:57 am »
Derek, the tank is actually not hard to remove should it be needed. But have fastened it to the base with a brass strap because I always remove the whole steam plant for cleaning. So I fill the gas tank when it's out of the boat. If I'll have to refill at the lake, I can just remove that strap and then the tank comes out easily.
Regarding the Regner gas filling valve, it seems a little easier to fill than the valves used in British tanks, which are very small and finicky.
KNO3
« Reply #133 on: June 24, 2012, 09:26:01 am »
Hi all, time for another update.
It might come unexpected, but the steam plant described on the previous page is due for replacement. No, it didn't break down or anything, it's just that I think there is a better combination or boiler, engine and gas tank possible.
Here's what I think the shortcomings of the last plant are:
- The engine has 4 cc volume (11 by 11 mm cyls) and is too big for the 45 mm propeller. This combination wastes steam. Since I cannot fit a lager prop, due to the space at the stern, the engine must be replaced.
- The gas tank with 38 ml is too small, it runs out of gas when the boiler is still over 1/2 full.
So I have decided to dismantle the steam plant. The engine, gas tank and boiler are going to the display shelf for now, I will reuse the other components in the future steam plant.
Here are the requirements for the new steam plant for the tug:
1. Self-starting and reversing engine around 2 cc to match the 45 mm prop.
2. Boiler suitable for the engine, could be the same as the old one or similar.
3. Gas tank of around 100 ml
I'll try to reuse the steam plant's alu base, the burner, condenser, the superheater and maybe other fittings.
Bernhard
« Reply #134 on: June 24, 2012, 03:34:20 pm »
Hi..ohh it is sooo nice a Tug,,,,,,,,, can a Cheddar Pintail not do it...or a small regner...
Bernhard
KNO3
« Reply #135 on: June 25, 2012, 09:23:36 am »
Thanks Bernhard. Which small Regner would you recommend?
I was indeed thinking of using a Cheddar Pintail since I was lucky to get one recently.
Bernhard
« Reply #136 on: June 25, 2012, 07:06:53 pm »
Hii,,,Try the Pintail...i have one to...strong liittle engine it is,,,,,,,,
Bernhard
KNO3
« Reply #137 on: June 27, 2012, 09:29:48 am »
Here's the new Saito boiler with a bushing for the water gauge silver soldered.
KNO3
« Reply #138 on: June 27, 2012, 08:08:10 pm »
Here are most of the parts for the new steam plant gathered, awaiting a pickle bath.
KNO3
« Reply #139 on: June 29, 2012, 08:31:11 pm »
Here are the Saito boiler and Cheddar Pintail freshly painted, baked, and the engine assembled.
Although it ran well before, I have also lapped all port and valve faces of the Pintail engine, because there were some scratches visible.
Boiler lagging and steam plant assembly come next.
KNO3
« Reply #140 on: July 19, 2012, 05:45:25 pm »
The boiler being insulated with a layer of felt. This will be covered with mahogany strips.
KNO3
« Reply #141 on: July 19, 2012, 05:52:26 pm »
I haven't taken pictures of all the assembly steps, so here is the new compact steam plant nr. 4 ready assembled:
In the hull:
Bernhard
« Reply #142 on: July 19, 2012, 08:58:04 pm »
Hi,,,,It real look and fit perfect, i like your great looking tug boat. :-))..a nice size it is,,,,easy to bring around to...
Regards Bernhard
« Reply #143 on: July 19, 2012, 11:46:14 pm »
Very compact KNO3  :-)) ...
I like the new vertical de-oiler
Is the boiler steam relief valve combined in the steam line into the lubricator?
Can you isolate the steam in the boiler?
What is the lever actuated valve at boiler height just near the gas tank end?.... the lever appears in the second image as being retained by an elastic band...could this be for the whistle?  :embarrassed:
What is the second component mounted between the chimney and the boiler relief valve?
This is why some love steam.......all very interesting :kiss: .......please more photographs as you progress................Derek
KNO3
« Reply #144 on: July 20, 2012, 03:08:35 pm »
Thanks all!  :-)
@derekwarner_decoy: The "new" condensate tank is actually the old one :-)
The safety valve is the one on top of the cross-shaped fitting, close to the manometer.
Yes you can isolate the steam in the boiler because on the small dome there is a steam regulation / stop valve. The steam pipe goes from it into the chimney, to a superheater coil, and then to the oiler.
The lever valve with rubber band you asked about is a whistle valve. It will be connected to the whistle on the exterior of the boat's smoke stack via a silicone tube.
KNO3
« Reply #145 on: July 21, 2012, 12:24:15 pm »
Hi all,
Here's the first steam test after finishing the steam plant. I have added the whistle which normally sits on the tug's (outer) chimney.
http://youtu.be/sN8JK_YAvI0 (sorry, I can't get the video to embed on this forum, perhaps a moderator can fix that)
« Reply #146 on: July 21, 2012, 09:51:55 pm »
Your link works fine.
Sorry, but we do not embed videos into the Mayhem Forum.
regards
ken
Pages: 1 2 3 4 5 [6]   Go Up
