Author Topic: Got a smoke mate  (Read 5141 times)
offshore1987
Re: Got a smoke mate
« Reply #25 on: July 19, 2008, 05:22:04 PM »
Umi your jjc thing is diffrent to mine? Did mr jjc make lots of diffrent ones?
All the best
Umi_Ryuzuki
« Reply #26 on: July 20, 2008, 02:42:51 AM »
All the best
The thing, or the thingy? :D
That unit was sent to me as "Broken, if you can fix it you can keep it."
It was different than the one I installed in Billy's Tito Neri also.
It has three different jumpers, rather than three pins and jumper setting one or jumper setting two.
And I was a bit confused trying to get a DC voltage reading off of the power leads to the mist unit.
Then it occured to me, try the AC settings... Bingo... the unit cycles between 1 and 54 volts AC.
The fan pulses for "puff", and runs constant for desiel.  However, this one seems to puff at Idle, and
I can't get it to change.  ???
New fan was 11.50 plus shipping AND stock fee... 15 total... :(
Bunkerbarge
« Reply #27 on: July 20, 2008, 10:17:22 AM »
As fact as I know Jim produced two versions of his "Old Smokey", the Mark 1 and the Mark2.
The Mark 1 came in two versions, one with a diesel control board that gave a boost on start up, and one with a steam control board that didn't.
The Mark 2 combined the two boards and incorporated a mode switch for changing over between the two and also incorporated a "show" mode which allowed the unit to operate without input from the motor, for instance when on display at shows.  I think the plug arrangement changed as well but without mine in front of me I can't remember the differences.
Umi_Ryuzuki
« Reply #28 on: July 22, 2008, 06:38:22 PM »
Somone, your side of the pond, just posted that they have leads to a 12vdc mist generator.
Hopefully he pops up with more info. I messaged for more info.
 8)
number-1
« Reply #29 on: July 23, 2008, 08:55:47 PM »
just read this thread for making smoke fluid http://www.modelboatmayhem.co.uk/forum/index.php?topic=8609.0 have not tried it myself but maybe worth having a look
cheers Les
