Author Topic: YouTube & other Videos.....!  (Read 2279506 times)
canabus
Re: YouTube & other Videos.....!
« Reply #1300 on: June 23, 2019, 12:36:51 pm »
Hi All
One of bgsteveg you tube clips
https://www.youtube.com/watch?v=zAqFjTnZ-Ns#action=share
He has posted a number of these from our club.
Canabus
C-3PO
« Reply #1301 on: July 09, 2019, 10:43:59 pm »
I watched this back to back 3 times - mesmerising...
https://www.youtube.com/watch?v=sDgeYfSZdL4
C-3PO
« Reply #1302 on: July 12, 2019, 06:38:55 pm »
What happens after you flush the toilet on a cruise ship?
RST
« Reply #1303 on: July 12, 2019, 09:54:03 pm »
Nice little infomovie that.  One thing I picked up from working / living with the engineers on boats (offshore vessels anyway) was if you have a shave or cut your hair, save the engineers some hassle and put the clippings down the bog not the sink.  Actually, it's something I do at home often now also.
How do you get videos to show on these posts please Martin?  I tried a few times.  Nothing usual for forums work -is it limited to you?
« Reply #1304 on: July 13, 2019, 03:53:02 am »
Hey Rich,   :-)
 No anyone can do it,  just not a .... a bit vapid....  but done easily enough....!
1. Select video on YouTube you want... obviously!
2. Click SHARE  underneath video,
3, Click Embed
4. Click Copy
5. Back here to ModelBoatMayhem, open a new post or reply as normal
6. Type video title or comment about video,  ( makes it 'searchable' ),
7. Click  'Insert Image' icon,
8. Paste  YouTube  'embedding code'   between the [ img] & [/img ]   ( no spaces  ),
9. Change both img's to html - ie. [ img] & [/img ]   to   [ html]   [/html ]   ( no spaces  ),
10. Post
taucher
« Reply #1305 on: July 15, 2019, 09:05:29 pm »
« Reply #1306 on: July 15, 2019, 09:50:29 pm »
Awesome Ralph!   :-))
 How is the camera mounted ????
taucher
« Reply #1307 on: July 16, 2019, 06:49:47 pm »
its not my. I found it randomly but its good.
Ralph
RST
« Reply #1308 on: July 16, 2019, 07:47:03 pm »
Hey Rich,   :-)
3, Click Embed
4. Click Copy
8. Paste  YouTube  'embedding code'   between the [ img] &    ( no spaces  ),
9. Change both img's to html - ie. [ img] &    to   [ html]      ( no spaces  ),
10. Post
Interesting, bit different process from other forums, SMF ones included.  Can't seem to follow what you said.  When I copy the embeded text it just shows as some form of a little square with a jagged line, no option to add, edit or remove surrounding captions.  PEBKAK maybe, but everything pasted is assimilated into a tiny meaningless box/Icon.
RST
« Reply #1309 on: July 16, 2019, 08:15:33 pm »
<iframe width="560" height="315" src="https://www.youtube.com/embed/C4Uc-cztsJo" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
...I follow the instructions and modify the html end bits exactly as described -but everything gets removed and modified automatically afterwards?
taucher
« Reply #1310 on: July 18, 2019, 04:53:56 pm »
I have invested the video. He use a (Insta360 One X) camera and cut wat you see from the 360° with a software.
This is genius
Ralph
« Reply #1311 on: July 22, 2019, 02:38:11 am »
Total Restoration Riva Aquarama Lamborghini 278
« Reply #1312 on: July 22, 2019, 02:51:00 am »
"Close .... but no cigar"!    ok2  - the 'insert image' tags are missing.....
It should look like ....
..... try it!   :-)
NB: I always use NON wysiwyg editior so you can see the code as you type! (Toggle Icon when in posting. )
« Reply #1313 on: July 24, 2019, 11:37:39 pm »
« Reply #1314 on: July 26, 2019, 05:43:13 pm »
Enough power.... even for Andy!
« Reply #1315 on: July 28, 2019, 03:23:49 pm »
Port of Amsterdam - Timelapse SAIL 2015
Taranis
  • Balne Moor MBC
ANDY
tsenecal
« Reply #1317 on: August 05, 2019, 11:31:32 pm »
an interesting take on making a display model...
https://www.youtube.com/watch?v=WwN0gscOzIE
and as to martin's statements on how to edit these things to make the video show up embedded... i have tried 6 times now to get the html tags to stick, and they refuse to, so, you get this instead.
Martin....   i tried, and it refuses to work....   you need to show us EXACTLY how you pull off this trick
Taranis
  • Balne Moor MBC
« Reply #1318 on: August 05, 2019, 11:41:38 pm »
<iframe width="560" height="315" src="https://www.youtube.com/embed/WwN0gscOzIE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Yes I agree, the html tags get removed
ANDY
« Reply #1319 on: August 06, 2019, 01:06:20 am »
Yes, an excellent video of the model U-Boot static construction  :-))  ..........Derek
C-3PO
« Reply #1320 on: August 06, 2019, 07:48:23 am »
You can't - the embed video html is trapped/filtered -  it's a setting in the forum setup - Martin has it enabled on his super "admin" user profile only!!
Reference - https://www.youtube.com/watch?v=s_NIAln2LJg
C-3PO
Taranis
  • Balne Moor MBC
« Reply #1321 on: August 06, 2019, 08:01:02 am »
That’s what I thought  {-)
ANDY
« Reply #1322 on: August 06, 2019, 01:36:01 pm »
Ah! OK, my bad, didn't realise that!
OK, new proccedure:
1. Embed code from Utube ( as above )
2. Add text as required
3. Post
4. Report to Moderator - "Needs HTML"
5. I'll add the HTML Tags.
I'm not envision 'loads of requests' so I can fix manually as required.
 How does that sound?   :-)
« Reply #1323 on: August 06, 2019, 04:42:53 pm »
« Reply #1324 on: August 06, 2019, 04:45:11 pm »
Did you mean:
Pages: 1 ... 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 ... 80   Go Up
Page created in 0.016 seconds with 20 queries.
