Author Topic: Midwest Models Fantail Launch  (Read 7133 times)
Philipsparker
« on: July 29, 2008, 03:49:23 pm »
I've started building a Midwest Models Fantail launch kit - bought on a whim from Oxford Models.
Description and photos at:
http://philsworkbench.blogspot.com/search/label/Fantail%20launch
Phil
Philipsparker
Midwest Models Fantail Launch - Finished !!!
« Reply #1 on: August 27, 2008, 08:25:31 am »
I've done it. And the rest looks pretty good to me:
Pleased Phil
Re: Midwest Models Fantail Launch
« Reply #2 on: August 27, 2008, 08:44:42 am »
Me too!  O0
Has she had her maiden voyage yet?
amdaylight
« Reply #3 on: August 29, 2008, 07:37:03 pm »
Boy that thin looks great O0, you did a real nice job on it. O0 I read your blog and you said that you could not get Sterno over there, you might want to check with a local food caterer as it is used as the heat source under warming trays to keep the water hot. In this country when they have a banquet away from a normal restaurant say in someones back yard the caterers would set serving trays on tables with cans of Sterno underneath to heat the water in the serving tray. Sterno is a pink jelly like fuel substance and we can get in several sizes from a little 4 or 5 oz can to a 5 gallon bucket depending on your needs.
On a note for your steam engine, boil your water first at home so you don't have to use as much fuel to get up to a working pressure. I have a Live steam railroad locomotive and before I go out to run I will boil distilled water and put in my thermos boiling hot. It will not be at a boil when I put it in the locomotive but will still be in the 180 plus degree range and does not take very long or very much fuel to get up to a full steam that way.
Andre
Page created in 0.592 seconds with 21 queries.
