December 12, 2025, 10:38:13 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
motor size for billings banckert?
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: motor size for billings banckert? (Read 4270 times)
granwood
Guest
on:
August 01, 2008, 02:53:59 pm »
what be best motor for billings banckert
Global Moderator
Full Mayhemer
Offline
You bark - I will bite!!!
Ivverkip, Inverclyde.
Re: moter size
Reply #1 on:
August 01, 2008, 03:02:04 pm »
What size and type of prop are you using?
Guy Bagley
Full Mayhemer
Offline
thames valley
Re: motor size for billings banckert?
Reply #2 on:
August 01, 2008, 03:18:36 pm »
i had one with a 380 in it, - way overpowered ! monoperm would also do the job..... but the question of prop size will effect the outcome...
boatmadman
Full Mayhemer
Offline
South Cumbria
Reply #3 on:
August 01, 2008, 04:54:39 pm »
I fitted a proper kort prop to mine and promptly burnt out the 380 motor.
I then fitted a small buhler (yes I know..heard it all before!), but its still going strong and doesnt pull too much load.
granwood
Guest
Reply #4 on:
August 01, 2008, 05:10:47 pm »
the prop i have is a 40mm 4blade, i have a unused graupner 500 7.2 motor wonder if could use that .i also have 7.2 battery charger and 3000 7.2 battery so if i could use them save me some money .thanks
granwood
Guest
Reply #5 on:
August 01, 2008, 05:12:03 pm »
sorry meant to say prop is a brass one.
Global Moderator
Full Mayhemer
Offline
Reply #6 on:
August 01, 2008, 05:18:54 pm »
Your motor would be a bit overpowered.
BUT
You dont have to run it flat out and some speed controllers can be adjusted so as to give reduced revs or even use the trim on the radio set instead of the sticks.
canute
Guest
Reply #7 on:
August 02, 2008, 04:40:16 am »
I'm using a Graupner Speed 400 with gearbox 2.33:1. I have also installed a larger 3 blade prob with in the nozzle where I had to sand the blade tips to fit. Lots of pulling power and with a large battery it runs forever. The photo shows the club barge I pull around with ease. My son bought the kit when he was 15 and just installed the prop shaft and rudders. He is now 37 and I completed the modified model this year. Long shelf life.
granwood
Guest
Reply #8 on:
August 02, 2008, 05:19:27 pm »
thanks all for help
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
