Author Topic: transmitter trouble???  (Read 3713 times)
J.beazley
  • The building never ends
« on: August 15, 2006, 08:56:55 am »
ive got a 6 channel transmitter with my helicopter running 35mhz with removeable crystal.
my question is, i use the same reciever in all my models with either a 27mhz or 40mhz crystal but can i change the crystal in my 35mhz transmitter so i can use the same transmitter for my various models???
Re: transmitter trouble???
« Reply #1 on: August 15, 2006, 12:06:33 pm »
No.  You need a transmitter for the band that the receiver will be using, and the appropriate crystals.
J.beazley
« Reply #2 on: August 15, 2006, 12:38:03 pm »
so theres no chance of buying a 40mhz tx and rx crystal set for my 35mhz transmitter as they wont work even tho the reciever is a 40mhz jobby???
Daryl
« Reply #3 on: August 15, 2006, 04:16:14 pm »
Correct, the transmitter and the receiver must both operate not only at the same frequency band 40mhz. 27mhz etc but on the same modulation, I.E. AM or FM.
Daryl
J.beazley
« Reply #4 on: August 15, 2006, 05:59:18 pm »
so i should get a transmitter that has removeable module aswell as crystal perfect
cheers for that ;D
A Model World
  • Model Boat Mayhem does what it says on the tin
    • A Model World
« Reply #5 on: August 16, 2006, 08:05:52 am »
you may find thats an expensive way of doing it with the changeable module its easier and cheaper to buy a 40meg TX
Daily flogging?of the ships crew will continue until morale improves
Page created in 0.02 seconds with 22 queries.
