Author Topic: fleetscale  (Read 3366 times)
modelman66
fleetscale
« on: August 11, 2008, 09:25:37 pm »
hi probably gunna get the 1/128 fleetscale bismarck would it run ok with 3 graupner speed 500e motors on 45mm props (p) type 12volt and two 30amp esp,s one controller operating two motors would this work?   12volt 20amp sla battery being used.
Re: fleetscale
« Reply #1 on: August 11, 2008, 10:15:30 pm »
Yes it should do, but fit a 25 amp fuse.
Also remember to fit heavy duty wiring from battery to the ESC.
If fitting a battery isolation switch ensure that this is at least 30 amps to carry the current.
Re: fleetscale
« Reply #2 on: August 11, 2008, 10:17:27 pm »
Not sure about the lead-acid battery but it will probably act a good tug with that much power.....  or a ski boat!
Mind you, better to have too much power and throttle back than have too little power and get caught out by an angry swan!
Have a look at Graupner Speed500 ECO motors or equivalent, nice smooth slow revving ones!  O0
