Thanks Dougal99, it appears i was reading the volts then, through the speed controller the voltage will have been 4V for the planned motor and 3.4 for the cheap maplins one. I do not know where to set the dial for the amps and which scale to use to determine the amps drawn, so i will need to check with the electrician at work - so a ribbing from him then.
So here is the results of the second test - will need more tests
What happened, attached everything and ran the bath, the hull was placed in and the main 4.8v-600mah was adjusted to suit a more favourable trim, now the first of these tests was with the cheap maplins motor, 18g and connected via a aircraft linkage with residue epoxy giving an interference fit.
Full throttle and if this had been a launch going from a battleship to the dockside then it would have been fine, several runs and it never improved.
Replaced with the next motor, weight at 30g and connected with again a peice of aircraft linkage tube but as this did not have any epoxy inside a short length of shrink tube on the prop shaft and a longer larger diameter piece of shrink tube shrunk on to both the linkage and the earlier tube, several dry free running tests showed this worked reasonably well.
Placed into water and adjusted the weights to suit the deeper draught generated by the heavier motor.
Full throttle, now it ran faster than the previous test run but due to the weight it did not appear to get up to any significant speed, akin to standard cruising for this type of boat, if i had to guess it would have been equivelent to about 25-30mph, the bow lifted slightly but as the bath is too short, getting up to speed was too hard, with crashing into either end a problem. being open top did have its problems with water getting in, so i will have to fit some tempory hull extentions to lift the sides allowing for the top to be open. Getting the motor inline is harder than expected, even with the coupling the rear end has a noticible wobble, this in turn translated into vibration and would probably explain why some of the power is lost.
I do understand that the problem of increasing the voltage to 6V may have a small effect, but the weight increase would probably negate the majority of the speed increase.
Although i charged the Rx battery i forgot to charge the Tx - hence the signal went straight from 80 to 20 in about a minute, luckily i had completed most of the tests and was trying to see why the motor was stuttering and running at full wack - the loss of Tx power probably explains that, it's a futaba skysport 6 complete with a 9.6v - 600mah niCD battery, think i will have to change that to a niMH.
So if steve does not mind, i will copy a few of the changes he's made to his, i have started the build of the superstructure with a start weight target of 80g (based upon 50% of the plastic in the parts to be fitted, although i will be following the kits instructions. I have not changed the pipes etc and done a bit of pre painting before assembling the parts, though under normal lighting the places i have missed show up quite noticably, will have to try harder.
The four pictures are the main parts of the superstructure, the right side and the steering console, to reduce weight the console part sits on the deck part, this means there is a double piece of plastic, this was removed, i painted the back black as there is no disernable view inside, I am going to change this to white after some thought, the two pins are the rear of the handle and are being removed to save some weight
, for the handle i will have to try and simulate wear by using silver paint (or should it be brass).
So I apoligise if some of the painting is rubbish - old eyes don't you know.
