Well – she’s had her bottom wet this morning, apart from the threat of a couple of swans with chicks turning up unexpectedly looking for a free handout of bread and then hissing at the boat – cheek!!!!
Time run was over an approximate distance of 6.3 metres, waves on the water were approximately 10-15mm (1/2” give or take), when heading with the waves, the time was approximately 6-7 seconds.
Reverse calculating this over the 248” (20 foot 8”) gives 35.4”/sec which results in a total speed of 17mph – 14 knots.
So 389 is now officially launched at 7:10 on the 9th June 2009 (should have waited till the 3rd of august 3 - 8 - 9) her nick name is Springer,
yes the nose dives under full power.
Going into the waves (remember these are 10-15mm high – ripples) the deck was seriously awash up to the bridge, the return with the waves coming up from behind was not much better, and as she gathered speed the nose ploughed under the water, covering the area consistently up to the bridge.
In conclusion – and a note for Steve Pickstock
, you will have to get the weight distribution spot on, on the next attempt at one of these, the motor and battery will need to be further back, at least behind the rear of the bridge so that the majority of the bow is out of the water, though I do not think that will make much difference anyway, it’s definitely a fair weather boat. I apologies for no photo’s as I had to get to work straight after, and there was no one to help take any.
