Sorry for the delay in replying
Very busy you know
Right i now have some time off so i will be taking all your comments and applying solutions as appropriate.
1. Prop shaft is straight & central
2. Rudder linkage is good
3. The boat is balanced OK
4. Think a glitching servo may be the problem.
I had a problem when i first put her on the water as by if i tried to accelerate and turn the boat would just stop until the rudder was back in the central position. I changed the receiver batteries (for new ones) but it still did this even with the TX just a few inches from the boat.
Then , and I'm not sure if this is OK , I attached the RX direct to one of the power pack's. This is when it started mucking about. Could this be the problem ? Too much voltage to the RX ?
I'm still very new to all this malarkey so any advise is good.
Thanks in advance
Steve...
