Hello John - you're saving me again!? Lovely to hear from you mate.? That would've been a very very good idea, I should have put some kind of sealer onto the insides of the boat.? Alas I didn't think of this, and the bottom went on with the inside of the boat just raw, untreated wood.? Hmmm, you've got me worried now!
I'm going to have to hope I can pull off a feat of veneer-application so neat and perfect that there are no leaks!? Also as you may recall I'm intending to treat this model to the sort of very shiney finish which needs lots of coats of varnish, so hopefully they will seal the boat very well.
Please keep these bits of advice coming, they're exactly the kind of help a rookie like me needs!? You live and learn, as they say, and in model boats I haven't done much living, so I haven't done a lot of learning either!!? Could you tell me a little more about this resin, what it is, how it works, what it's used for, etc. I'd be very grateful.
Here's how I got the bottom stuck on.? Obviously the top is planked over so you can't see in to check whether you're doing it right, you just have to sit and think about it for a while, plan the best way forward.? ?As you can see, I lack enough, grips, tools, and a workshop, however I make up for that with a plentiful supply of tinned tuna, tomatoes, vinegar Lloyd Grossman pasta sauce, and gaffer tape.? Ingenuity saved the day.? It was just a matter of finding anything about the right size, putting it on the boat, and then very tightly wrapping it round with gaffer.
I had to go outside for this part (into the snow!!
), as the fumes from the glue tighten up my airways and I get very wheezy, and even have problems breathing at night!
I actually got to wrench the bottom into almost fitting, using gentle persuasion. The position that it set in isn't too bad at all.
And after I'd finished I made a nice pasta bake for our tea!!
