Author Topic: Flashing tape  (Read 989 times)
Hagar
Flashing tape
« on: August 30, 2008, 04:40:22 pm »
Not really a tech question, but I guess this is as good a place as any.
Has anyone used aluminum Flashing Tape, you know, the stuff you use on the roof around exit points and the like, for detailing a boat hull below the water line.
Sticks like the perverbial to a blanket, and is 100% weather proof...? And a bit easier to work with than alu sheet. Would it stay on a hull is the big question.
Re: Flashing tape
« Reply #1 on: August 30, 2008, 05:45:19 pm »
Might be a bit soft and prone to marking from knocks maybe?
andyn
Re: Flashing tape
« Reply #2 on: September 03, 2008, 04:58:44 pm »
Would peel right off after continuous sailing use.
Would need to be stuck on with epoxy or simalar completely WATERPROOF glue.
