Author Topic: RC tiller arms?  (Read 8512 times)
Martin [Admin]
RC tiller arms?
« on: September 01, 2008, 09:02:41 pm »
Why are model tiller shaped this way?
andyn
Re: RC tiller arms?
« Reply #1 on: September 01, 2008, 09:27:51 pm »
So that if it goes too far the servo can still push it back around.
Glad to be of assistance O0
Martin [Admin]
Re: RC tiller arms?
« Reply #2 on: September 01, 2008, 10:11:34 pm »
Why aren't they just straight?
portside II
  • tugs at rest
Re: RC tiller arms?
« Reply #3 on: September 01, 2008, 11:29:53 pm »
duno maybe its to give more leverage ,if they were straight then you would have a max of 90 deg travel max .
daz
I like to build my boats to play with, not to just look pretty,so they dont !
Re: RC tiller arms?
« Reply #4 on: September 02, 2008, 10:40:16 am »
I tend to make mine out of 13A plug legs.  They're just straight and work.  In normal use, the servo only has 45deg each side anyway.
andyn
Re: RC tiller arms?
« Reply #5 on: September 02, 2008, 03:29:51 pm »
As I said, they are shaped to give the servo authority at greater legnths of travel.
If you at a 45 degree (pushrods) angle into a straight tiller, the servo has no authority, so needs more power to push it, however in that style, it can move it with ease.
portside II
  • tugs at rest
Re: RC tiller arms?
« Reply #6 on: September 02, 2008, 06:16:15 pm »
Aint that what i said ,i think err O0 .
daz
catengineman
Re: RC tiller arms?
« Reply #7 on: September 02, 2008, 06:50:59 pm »
The design is from ACKERMAN GEOMETRY principles
This is not that important unless you are into differing rudder angles (multi rudder configs) if you are into race car etc then yes it comes into play to get the inner and outer wheel turn angles correct.
as for rudders it is whether your arm is "over center" that matters so that an equal arc both sides of the center can be obtained by your servo movement.
servo arms rudder arms are available in straight as well as angular
IMO
Oh I do use the Ackerman system when I build twin rudders it gives a very good turning circle.
R
andrewh
Re: RC tiller arms?
« Reply #8 on: September 03, 2008, 04:54:21 pm »
Cos the back of boats are pointy?
I have never seen one fitted this way round before - always with the arms facing forwards.  Ihad assumed that it was to give more rotation before the backward going arm thumped the transom
I havn't used them myself until tonight!  I have just made the rudder and gear for my Higgins PT boat, and used one of these - it will go on with the arms facing forward.
andrew
andyn
Re: RC tiller arms?
« Reply #9 on: September 03, 2008, 04:56:50 pm »
The arms in my Higgins are facing forwards too, just noticed that  O0
Martin [Admin]
Re: RC tiller arms?
« Reply #10 on: September 03, 2008, 04:59:20 pm »
  Clever!  O0
andrewh
Re: RC tiller arms?
« Reply #11 on: September 03, 2008, 05:06:01 pm »
Yur, Martin, I'm a deep thinkuh
and i are a ingeeneer,two
andrew
Bryan Young
Re: RC tiller arms?
« Reply #12 on: September 04, 2008, 06:31:06 pm »
Dunno why they are shaped that way but I find that the lack of a centre that fits a servo a real pain in the tripes. All sorts of weird and wonderful servo attachments come in little bags, but not a decent size "tiller" arm.
Notes from a simple seaman
787Eng
Re: RC tiller arms?
« Reply #13 on: December 31, 2008, 12:09:43 pm »
Hello,
I'm after a tiller arm like the one pictured, cane someone let me know a source of them?
Mark
maninthestreet
Re: RC tiller arms?
« Reply #14 on: December 31, 2008, 12:30:38 pm »
787Eng
Re: RC tiller arms?
« Reply #15 on: December 31, 2008, 01:11:39 pm »
Thanks for the fast reply. :-))
gingyer
Re: RC tiller arms?
« Reply #16 on: December 31, 2008, 05:13:46 pm »
good point Bryan
All the servo horns are too small I think they should come with some larger horns >>:-(
Bryan Young
Re: RC tiller arms?
« Reply #17 on: December 31, 2008, 06:51:11 pm »
After a little thought I now think the arms are angled to somewhat negate the effect of a rod traversing an arc so as to give the most advantageous result.
That sentence sounds a bit "odd" but it is the only way I could put it! Sorry.BY.
Peter Fitness
Re: RC tiller arms?
« Reply #18 on: December 31, 2008, 10:22:53 pm »
Pardon my ignorance,  :embarrassed: but what is the Ackerman system?  :o
Peter.
Re: RC tiller arms?
« Reply #19 on: December 31, 2008, 10:49:27 pm »
Peter....courtesy of GOOGLE..........
Ackermann system
mechanics
Main
Aspects of this topic are discussed in the following places at Britannica.
Assorted References
use in trucks ( in truck: Steering )
Steering of trucks, with their relatively heavy loads, was a problem until power steering came into use in the early 1950s. Steering is always by the Ackermann system, which provides a kingpin for each front wheel. Maximum cramp angle of the front wheels is about 35 degrees. The minimum turning radius is dependent on the wheelbase. A few vehicles have been built with two steering axles in the...
However I suspect R/C servos as we know them had their origins for military applications...[seems strange but I would never take the time to count] ........ :-)) the number of splines on the servo output shaft has a one off location to the true cross axis of the pairs of arms or pre drilled holes on the servo arms or disc
But again just simple mechanics........if we use larger centers on the servo horns, we increase our rotational motion for any given requirement but also reduce the torque load on the servo...same applies in reverse for smaller centers on the servo horns.....Derek
OMK
Re: RC tiller arms?
« Reply #20 on: January 01, 2009, 01:53:32 am »
"Why aren't they just straight?"
Neat question. But judging from all the given answers it seems that nobody is really none too sure -- me included.
A lot of the fly boys are using the similar pull-pull system on their rudders, but mainly by emplolying cables, as opposed to using piano wire.
I think the main reason for the V-shaped Ackerman is to counter any glitches or snags as the control surface is moved through its arc. You get a nice, silky-smooth control of the surface if the 'V' end is facing AWAY from the servo. Having it the other way around means you would probably run into all sorts of problems. Those same problems can occur if the Ackerman is straight.
My take is that it's a lot to do with geometry. For instance, if it were straight, you would likely notice one side of the cable would stay nice and taught throughtout its traverse, while the opposite side becomes sloppy (and vice-versa).
An engineer I ain't. All I know is that Mr. Ackerman's invention works.
GG
Re: RC tiller arms?
« Reply #21 on: January 01, 2009, 12:02:26 pm »
Will someone please tell me what "Ackerman Steering" has to do with rudder tiller arms in model boats?
I can understand its use in road vehicles where the wheels have to follow different radius circles when turning if you want to avoid any element of sideways motion between the tyre and road surface, but in a boat?
The reason some control horns are angled forwards on model aircraft is to get the linkage in line with the hinge line and thus produce even movement.  True, in some cases, like ailerons which can benefit from more "up" than "down", this is not wanted.
If this shape of tiller arm was any advantage than all model manufacturers would use it, which they clearly do not.
GlynnG
Re: RC tiller arms?
« Reply #22 on: January 01, 2009, 01:04:00 pm »
I suspect that the Ackerman thing comes into play where there is more than one rudder, same as the difference between steering a Reliant Robin and a Morris Minor.  It does make some sort of sense when you consider that the inboard rudder should get a greater deflection than the outboard one to describe the tighter radius in any turn.
I haven't got the drawing stuff out to check the geometry, but it might also be that there is a different response between left and right which MIGHT be significant in a single prop setup, or not, as the case may be.
Peter Fitness
Re: RC tiller arms?
« Reply #23 on: January 01, 2009, 08:14:30 pm »
Thanks, Derek.............I think  {:-{
Peter
Re: RC tiller arms?
« Reply #24 on: January 01, 2009, 10:31:14 pm »
I did a google for ackerman and found this link
http://autorepair.about.com/library/a/1g/bl489g.htm
which explains the important bits that brittannica leaves out, and itself has a link to an RC car forum where it explained fully.  The differential toe-out on lock would appear to apply equally well with rudders in fluid as with front wheels on land.
