Pages: 1 2 [3]   Go Down
Author Topic: Pictures/information about your work bench/working area please...  (Read 32028 times)
bobinnit
Re: Pictures/information about your work bench/working area please...
« Reply #50 on: September 14, 2008, 08:28:45 pm »
 :) Here's my work area, in the process of having a good clear up. So will post more pics as the work area's appear   ;D ;D
bobinnit
« Reply #51 on: September 14, 2008, 09:00:34 pm »
lol Martin  O0 O0 O0 O0 O0  eating beans in " your worksop" again. Looks like another Cheynobl to me  ;)
Fast Electricals
« Reply #52 on: September 14, 2008, 09:15:27 pm »
Gosh is that a 101 there are not many that can load them up    ::).
Proteus
No, its a Trio TS820s. A similar vintage to the 101 and yes it does need loading up (all part of the fun)!
G7AQK
« Reply #53 on: September 14, 2008, 11:15:27 pm »
A picture of my first workshop......
How can you be so insensitiev Martin in posting shuch an image.Hundreds of lives were lost in this incident and they people of Chernobil are STILL suffering today.All the farmers not lnly in the UK but all the countries around Chernobil were severly infected livelyhood were lost due to the radiation problems,which in fact are still there today.
THIS POSTING IS THE ULTIMATE IN BAD TASTE AND SHOULD BE REMOVED IMMEDIATLY
oldiron
« Reply #54 on: September 14, 2008, 11:18:30 pm »
Here in southern Ontario (Canada) we are blessed with basements in the majority of our homes. Most people usee them for storasge, party rooms, spare bedrooms and such, however, a few of us with more productive minds ( :D) us them for some really neat things.
 In my case I build live steam, fix old machinary and build baots. Consequently I've divided my workshops into lite (for boat detail and such work), heavy (for machine work on live steam and building big boat bits) and super duty where the welders and heavy mob work (this shop is outside).
  Although it keeps me out of the wifes hair, and she never cleans it (thank heaven), she does complain , from time to time, of the banshea like noises and gutteral groans coming from the depths of the house.
  If I have anything to suggest, ist get rid of the excess you don't use..............now here's the hard part.........figuring out what is the excess you won't use. I figure its all gold that will, in the fullness of time, be consumed.
HLR
« Reply #55 on: September 15, 2008, 07:15:47 pm »
replaced the greenhouse last year with a 8 x 6ft pent shed, insulated, heating, lighting, power, radio and good ventilation.
Steve.
Fast Electricals
« Reply #56 on: September 15, 2008, 10:34:38 pm »
I'm sorry it is far too organised, clean and tidy. Please mess it up a bit, you are making me look bad. If my wife saw the photos of your workshop, my life would not be worth living!!!!!!!
Life is too short to tidy up!
HLR
« Reply #57 on: September 16, 2008, 05:05:02 pm »
must keep it tidy Neil, If I don`t the good lady will get in there and I will never find anything, {-) {-)
Steve
barriew
« Reply #58 on: September 19, 2008, 03:30:58 pm »
This is my shed - about 8x6 was a big as I could fit between two trees. Its insulated and has two heaters - a 500 watt wall mounted convector with frost stat, and a 120 watt tubular heater under the bench for warming my toes :D The floor is carpeted - not lost anything important yet ;D, as this is the only insulation to the floor - I can only just stand up as it is, so couldn't afford to lose any height by insulating the floor. When (if) we move next year I hope to be able to get a bit more space so I can set a couple of power tools permanently.
Barrie
Seaspray
« Reply #59 on: September 19, 2008, 04:51:49 pm »
Hi
After re felting the old shed last year with good quality felt and its settled down now and looking good. and has power now.
I would like to insulate it.
What materials has been used by those that have insulted their worksheds including what it has been finished off with ?.
Martin
barriew
« Reply #60 on: September 19, 2008, 05:50:49 pm »
The walls and roof of my are insulated with sheet expanded polystyrene from Wickes. It is finished with match boarding - easier to handle than sheet materials. When I do the next I will add more battens to give greater rigidity and facilitate fixing shelf brackets etc.
Barrie
Roger in France
« Reply #61 on: September 19, 2008, 06:07:09 pm »
I was told not to use expanded poly. as mice love to tunnel into it.
Mine is concrete block construction and insulated with 80mm fibre glass panels, between 80mm timber uprights, then covered with 30mm chipboard. The ceiling (under a Roman Tiled roof) is also 30mm chipboard with 80mm glass fibre panels laid on it.
For flooring I have wooden duck boards.
For heating I have two portable electric convector, fan assisted heaters - which I have never turned on in two years!
The workshop is 18m X 10m. One end is divided into two rooms. One room contains the pool filter equipment and the other is a dedicated clean room for painting etc.
Roger in France.
HLR
« Reply #62 on: September 19, 2008, 09:45:21 pm »
Hi Martin,
My shed had a 2" x 2" frame, I replaced my four windows with a new frame I made of "2 x 2" and made the two centre ones openers, doubleglazed the glass for better insulation. Clad all the inside with double sided foil insulation that is used in between roof rafters. filled all joins and gaps with expanding Polly foam Installed two air vents on opposite corners at roof height for ventilation. Then clad all the inside with 1/2" ply. sealed all the joints, laid  1/2" insulation on the floor, then used up the laminate flooring I had left over from a job I did in the house. Ran 1 1/2" skirting round the bottom so the floor still " floats". Then wired it all out, job done!.  Took my time doing it, it is easy to keep clean, weatherproof, and its my bolt hole. Spent about £50 on materials, had quite a few bits and bobs laying around which I used.
Steve
FishdockBob
« Reply #63 on: October 02, 2008, 11:07:35 am »
Here,s a few pics of my workshop. Built within the last two years it is in two area,s, the reason is because I only got into model boat buildin about 18 months ago and the original shed I built was 12 feet by 6 feet. I then extended this workspace by building a smaller 8 foot by 6 foot extension onto it. The original shed is where I do my filling/sanding and fibreglassing and also houses my small lathe and piller drill. The new part is more comfortable and comes complete with television radio and heater, also houses the band saw and sanding station.
« Reply #64 on: October 02, 2008, 11:19:05 am »
I've heard of "curtain tie backs" but what sort of weather are you expecting Bob?!  :o {-)
FishdockBob
« Reply #65 on: October 02, 2008, 11:26:35 am »
HAHA, thanks for noticing that Martin,They are very heavy velvet curtains and come in very usefull in the winter months in keeping the cold out of small workshop.
Pat Matthews
  • Get your boats wet!
    • Matthews Model Marine
« Reply #66 on: January 09, 2011, 09:10:37 pm »
Our one kid has moved out (a few years back actually), and I now have almost 100% squatter's rights to the house's basement... and a little spillage into the garage too!
The "clean" part of the basement (with carpet) is my office/library/model storage area.
The toasty warm furnace room is my workshop, just sizable enough.
Someone elsewhere was asking about parts storage... I found some plastic sliding drawer units, which are usually too flimsy for my taste, but I made them alright by screwing them down to some bookshelves. Great for slightly bigger stuff, like spare props and ESC's.
For many other Good, Bad, and really Ugly shops- see:
http://www.rcgroups.com/forums/showthread.php?t=898408  and
http://www.rcgroups.com/forums/showthread.php?t=1165294
Pat Matthews
Get Your Boats Wet!
hollowhornbear
« Reply #67 on: January 09, 2011, 09:25:04 pm »
think we're all jealous now, at least i know i am.!
although i'd be in trouble wouldn't want to come out of there.
Pat Matthews
« Reply #68 on: January 09, 2011, 10:12:37 pm »
The bathroom is upstairs, which means I have to come up for, er, air, now and then...
Pat Matthews
Get Your Boats Wet!
« Reply #69 on: January 10, 2011, 11:37:20 am »
Hi Pat,
Nice workshop ....... one thing I don't understand,   I can see the floor?!?!?
 How have you archived that?   Is it a camera trick?!?!  ok2
Pat Matthews
« Reply #70 on: January 10, 2011, 11:58:50 am »
Yes, sorry about the mess in the third pic, the area was under reconstruction at the time...  %)
But my place is NOTHING... if you look through the links I gave, you'll come across THIS:
Pat Matthews
Get Your Boats Wet!
Dave43
« Reply #71 on: February 16, 2011, 09:08:58 am »
mine just after visit from fire brigade still dont know what caused the disaster.
pugwash
« Reply #72 on: February 16, 2011, 09:47:08 am »
Hells bells Dave that looks awful - did you lose everything????
Geoff
« Reply #73 on: February 16, 2011, 01:36:22 pm »
Looks like a fire caused it Dave. :-))
 Only hope the insurance is going to shell out. Didn't have any Lipos on charge??
  Me mate in Michigans workshop looks as big as Pats, seen smaller Industrial workshops than those.
  Regards  Ian
Klunk
« Reply #74 on: February 16, 2011, 03:33:30 pm »
will take pics of my 2 sheds and loft..................even worse than thread like this before!!!!!! HAVE INHERITED ANOTHER 5 BOATS IN 6 MONTHS!!!!!
full time penguin
Pages: 1 2 [3]   Go Up
Page created in 0.596 seconds with 17 queries.
