Author Topic: multiplex radio sets  (Read 3960 times)
boatmadman
« on: September 07, 2008, 09:55:05 pm »
I would be interested to hear people's opinions of these radio sets:
http://www.westbourne-models.com/erol.html#4178X0
catengineman
Re: multiplex radio sets
« Reply #1 on: September 07, 2008, 09:59:40 pm »
a quick read and I see 41Mhz only two model settings
not for me but could fit in with some models
R,
omra85
« Reply #2 on: September 07, 2008, 10:22:48 pm »
I think it should be 12 model memories!
Have a look at
http://www.modelspot.com/mpx/cockpitsx.htm
Nice set with well placed controls. I haven't got one - but Christmas is not far away  O0
Danny
catengineman
« Reply #3 on: September 07, 2008, 10:29:46 pm »
That make a better read.
have to stick with my FX 18 or the spanner will kill me >:(
Some sort of question on how much my models are costing?
(dont know what she's on about)
FullLeatherJacket
« Reply #4 on: September 08, 2008, 08:42:27 am »
A couple of customers have reported that they were a bit disappointed with these sets because they are so obviously biased towards aeroplanes and lolliecopters. Generally speaking, though, Multiplex has been around for a long time and has a very good reputation for quality and reliability. If 'twere me then I'd go for this set in preference to the Futaba 2.4GHz thing; I was certainly not impressed with that  set.
Ref the Multiplex Cockpit computerised radio, I guess it's a question of tailoring its various bells and whistles to suit your particular needs - and a clever chap like you should have it sussed out in a jiffy!  ;)
FLJ
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #5 on: September 08, 2008, 12:09:03 pm »
If you want a boat oriented radio thats a step up from the Robbe F/FX range, i can thoroughly reccomend the Grauper range. The Tx (Mc-19 and above) have a built in software nautic module and you can assign every button, switch, trim button a function to control a proportional channel or switched channel. They also have expansion wells should you need more. Comes in 40mhz but Gaupner also sell 2.4Ghz HF modules if you want to go down that route.
g7tmu
« Reply #6 on: November 16, 2008, 11:06:07 am »
I have had a Multiplex Cockpit SX R/C set for almost 2 years now and I have used it for many hours without problems so far!
As someone else said the instructions are for aircraft use only, but then I have never seen any 40mhz 4+ channel sets which were any different! That said though the instructions are very clear and there has been several articles in the model magazines on how to set up these Multiplex sets for model boat use, mixers and the like. I have filed away copied of these articles with the Multiplex handbook, although as I am now almost 100% an R/C yacht operator I am not likely to need them. The TX/RX cover all the standard 40 Mhz frequencies ie. from 40.665 to 40.985.
I bought mine as I already had umpteen 40mhz receivers (with crystal type) and the Multiplex TX will work perfectly well with them. Equally my old Hitec Focus 40mhz 4 channel TX works equally well with the Mutiplex RX. If you only have 1 or 2 models then a 2.4ghz might well be a better bet, although I wouldn't want to put a £60 RX in a Club 500 model, but maybe that's just me being over cautious! The Multiplex TX has a slightly more quality feel to it than a Futaba 2.4 GHz TX to me at least, although the Futaba seems to work fine.
The standard TX aerial is a bit long, but the alternative stub aerial works fine and gives me all the range I have ever needed. You can turn the TX stick ratchets/springs on and off using a torx key, which is clipped to the back of the TX. For yachts I use a ratchet on the left hand stick, but when I raced Club 500's I simply set it to a sprung centered stick for the throttle. The TX requires a 3 pin DIN plug for the charging lead which is a bit of a nuisance, but you can get these plugs by mail order from Squires in Bognor, if you can't find one locally.
There are 12 model memories and they can have a 6 alpha/numeric character description and there are various timers which you can set for model runtime and TX on time etc.
Victor g7tmu
gary r uk
« Reply #7 on: November 16, 2008, 07:15:36 pm »
guys
i think mcat has this model tx
gary
SAILING WITHOUT FAST ELECTRICS PRICELESS
boatmadman
« Reply #8 on: November 16, 2008, 07:28:32 pm »
An update on my radio set question, I am now the owner of a Robbe F14 Navy, it came with a 2 channel expansion fitted. I have since expanded it by a further 2 channels - now 8 channel.
I was lucky enough to buy this set from another forum member - thank you.
Page created in 0.011 seconds with 20 queries.
