Author Topic: Graham industries TVR1A  (Read 16537 times)
surteanders
« on: September 12, 2008, 10:52:42 am »
Hello!
I was trying to get in contact with Graham industries, but they never answer my mail?
Are they still in business?
Anders.
Bernhard
Re: Graham industries TVR1A
« Reply #1 on: September 12, 2008, 07:00:26 pm »
hi...............yes,,,,,,,,,,,,,but can be sooo slowwww to replay
regards Bernhard
catengineman
« Reply #2 on: September 12, 2008, 07:16:34 pm »
Steam power! takes time to get up pressure  {-) before results are seen
Sorry just couldn't resist ;D
andywright
« Reply #3 on: September 12, 2008, 10:59:17 pm »
He does reply quickly, I emailed him last week, he is away on business this week.
« Reply #4 on: September 13, 2008, 08:15:54 am »
                http://www.grahamind.com/
wideawake
« Reply #5 on: September 13, 2008, 09:56:18 am »
I'd not come across this engine before.   Anyone got experience of it in use?   It's not a Proteus but it might do for my Wideawake.   Pricewise it seems very reasonable b ut is there a reason?
Guy
« Reply #6 on: September 13, 2008, 11:46:26 am »
Thats a nice looking engine, and seems to be very well manufactured, and the price, unbelievable, you can't really go wrong
Tempted myself now  O0
Bernhard
« Reply #7 on: September 13, 2008, 03:42:30 pm »
hi.........i have 3  of the 2 cylinders ans 1 .1 cylinder...nice and good looking they are,,,bot not the stronges in the long run,,,bot for that price they are okay..here is a link to 2 off mine
regards Bernhard
                               http://www.youtube.com/watch?v=CICE-XgTszA
                              http://www.youtube.com/watch?v=UQlqhgRgz9g
surteanders
« Reply #8 on: September 13, 2008, 06:19:06 pm »
Hello !
I am planning to power Caldercrafts "Imara" with two TVR1A.
Are they powerful enough?
Planning to use two 75 mm props
Anders.
wideawake
« Reply #9 on: September 13, 2008, 07:18:19 pm »
regards Bernhard
Thanks Bernhard.  That's useful.   I was a little concerned about the mention of machined aluminium parts in the info.   Also it'll need a displacement oiler added.   That'll add another £20 or so to the cost.   Still looks good price-wise compared with other possibles.   i also noticed that the forward/reverse lever seems to have a rather long throw.   have you had any problem operating it with a servo?
Guy
BarryM
« Reply #10 on: September 13, 2008, 09:03:20 pm »
Guy,
Try searching on TV1A on this forum and you should find the discussion that I started a while back with the same question!  Also remember to add postage and tax to the screen price.
Cheers,
Barry M
BarryM
« Reply #11 on: September 13, 2008, 11:41:22 pm »
Sorry, I meant search on TVR1A
wideawake
« Reply #12 on: September 14, 2008, 09:27:25 am »
Yeah I thought you probably did :)
As you say, useful comments in the previous threads.   WRT tax etc. if I buy one, not such a problem.  My partner's brother lives in the US so could buy it and send it to me as a "present"!  WRT steam control, I imagine that as with Stephenson gear, the forward/reverse might also act as a speed control.  Otherwise the usual suspects offer lever operated steam valves, though as you say, it all adds to the cost.
Guy
kiwimodeller
« Reply #13 on: September 14, 2008, 12:09:21 pm »
Guy, which "usual suspects" offer servo operated steam valves for use as a throttle? ACS Engineering used to but they have closed. Searched these forums and came up with quite a list of well reccomended suppliers of steam fittings etc but could not find a throttle valve on any website. I would prefer a rotary disc valve if possible large enough to take 3/16" pipe for a fairly large single cylinder engine similar to a Stuart 10. Thanks, Ian.
AlexC
« Reply #14 on: September 14, 2008, 01:26:55 pm »
Guy say's
Please note.... Neither Stephensons gear, nor the Hackworth gear used by the TVR1a are for the purpose of SPEED control.
Their purpose is to provide a means of adjusting the valve timing (cut-off) to permit better use of STEAM EXPANSION, thus giving better fuel/steam economy and for reversing the direction of engine.
They should be used in conjunction with a steam regulator for correct speed control. (as in full size practice)
 O0
AlexC
wideawake
« Reply #15 on: September 15, 2008, 11:12:00 am »
HI Alex
Yes I knew/thought/suspected that was the case but also knew/thought/suspected that if the lever is positioned in the middle it effectively stops the engine.  In practice, as you say, I'd fit a servo operated steam valve as well.  Actually if I was going to machine up the D10 casting set I have, I'd be tempted not to fit the reversing gear kit (which I don't have, and which I gather is fiddly to machine and set up) but to get one of the forward/reverse gearboxes offered by Mainsteam models.
Guy
logoman
« Reply #16 on: September 15, 2008, 11:42:35 pm »
Kiwi,
RC steam valves can be hard to find, particularly for imperial sizes.
Kramer does a superb metric one, perhaps he's do you a special?
I've bought a couple recently from Polly Engineering in the UK. £16.50
They've been out of stock for a while, not any longer.
http://www.pollymodelengineering.co.uk/
I'm in the UK, and I'd be happy to forward them to you for free if their postage is high.
(assuming you're in NZ, you might not be :)
kiwimodeller
« Reply #17 on: September 15, 2008, 11:50:10 pm »
Thanks for the offer. I did eventually find a listing in the Bruce Engineering part of their website but without picture or specs of pipe size etc. It is a pity ACS Engineering went out of business as Sandy was extremely helpful and had just the right thing in his stock. I am going to have one more attempt a getting the present system (a tapered needle valve) to work and if not will contact Polly and get back to you if there is any difficulty with posting. I usually get most things sent here without problems. I will also see if anyone else in the club wants to order as the postage on several items is usually not much more. Thanks again, Ian.
logoman
« Reply #18 on: September 15, 2008, 11:55:05 pm »
The Polly one is 1/4" 40tpi for 1/8 pipe. not a work of art but would be better than the needle ;)
wideawake
« Reply #19 on: September 16, 2008, 08:15:02 am »
Hi Kiwi
Yes, polly/Bruce Engineering was the "usual suspect" that I had in mind.
Guy
mogogear
« Reply #20 on: September 17, 2008, 05:26:48 pm »
Kiwi,
Hello Miles- welcome to the fray here!! I too just ordered a steam valve from Polly for use on a Graham engine that I will be putting in my Alexandra...
WW- I think you boat is a tad bit too large for the Graham from my understanding.
The reversing shaft used on the Graham twin can actually be run out the other side of the engine for a much shorter throw.
Here is a picture of that set up
The shaft has been reversed to face the opposite side of the engine that it normally projects from. And it has been shortened. A servoe for F/R and one for the steam valve( an ACS valve shown)
AlexC
« Reply #21 on: September 17, 2008, 07:07:46 pm »
mogogear,
looking at that installation picture, very tidy I must say, it would appear that the steam control valve is connected up the wrong way round.
The steam inlet from the boiler should go to the TOPmost connection and the engine fed from the LOWER connection.
As shown it looks to be the other way round, which will/can lead to the control disc/cam being lifted from the valve port face, leading to less acurate control of the steam.
If connected the correct way round, the steam pressure, in the top half of the valve, holds the disc/cam against the port face thus ensuring correct operation.
Just an observation.
AlexC  O0 O0
mogogear
« Reply #22 on: September 17, 2008, 07:14:18 pm »
Your observation could be correct- but the picture is not of my boat--it is somebody else's( sorry a web-napped photo :embarrassed:) .. It was a good illustration of the Graham installed with reversing and speed control servo's in place. I just wanted to show the reversing gear linkage...
I do agree that the owner used the most circuitous route for the steam supply line, but since it is reversible, I do not know why steam feed can't be to either side of the engine...?
I may just not be thinking enough..
AlexC
« Reply #23 on: September 17, 2008, 09:30:08 pm »
Mogogear,
Ok, I was not aware it was not your model.
The connections for steam and exhaust at the engine are correct, and cannot be reversed. This is dictated by the valve gear.
The TVR1 is a slide valve engine and the steam and exhaust must allways remain on the correct sides of the slide valve.
Engine Reversing is a mechanical function of the valve gear not the steam/exhaust direction.
The two connections I was referring to are those on the steam control valve. These should be the other way round and should not be reversed as they are in the picture.
I.E the valve connection shown as coming from the boiler, via the displacement lubricator,  should be the outlet to the engine, whilst the one shown going to the engine should be the feed from the boiler/lubricator.
Hope that explains it a bit better.
AlexC  ;)
mogogear
« Reply #24 on: September 17, 2008, 10:00:03 pm »
Ahhh.. there we go mate... on the engine side- my oscillator familiarity kicked as opposed to slide vlave..
I have never seen the one from ACS before and you have explained it well ..Thanks!! There are a couple of us over on the Unofficial Mamod site that are about to embark on using the Graham in some launches and see if we like it. The steam valve has been hard to source( and lack of one was an issue as the reversing mechanism on the Graham has no speed control) and now that Polly has them in stock again, and Spektrum has such a nicely affordable TX =DX5e, 3 channel control concerns are waning.
Thanks again for your observations
Page created in 0.831 seconds with 17 queries.
