I had one of those cheap drills with knackered batteries so dismantled it and fitted the 'no name' motor into a speedboat hull, direct drive onto a 40mm three blade prop. With twelve cells producing 14.4V the motor screamed round and the boat went like the clappers. The drill was a two speed 14.V with a high low/ ratio gearbox. I figured the motor was very high torque because when I opreated the trigger, the machine was not only fast but the drill would twist in the hand as it shot up to full revs.
I think this would be a good indication of whether the motor was a high or low torque unit before you even try taking the drill apart. Some machines are simply powered screwdrivers and have a single low ratio box fitted, I believe these have the low torque high rpm motors which are generally no use for most models as a primary power unit.
As to another feature, my motor was fitted with a fan which is obviosly meant to cool the motor so perhaps another indication of a high power unit here. I can't give you any current readings under load on this one as I have forgotten but I think we were up in the low teens if memory serves me correctly, needless to say I only got five or ten minutes out of a 3,300mA pack but the boat, although heavy does go like stink!
