Hi capt spalding,
Do you need the skeg to be removable so you can remove the rudder?
If so my usual method is to do the following;
1, Get hold of some small matching size brass nuts and bolts. I usually use 6ba thread size
2, Cut a strip of brass to fit the inside edge of the hull (inside the keel)
3, on one side of the strip clean/degrease and mark the hole centres and drill two holes.
4, transfer the position of the holes in the brass plate to the inside of the keel and drill through the hull
5, solder two brass nuts to the pre-drilled brass strip
6, put some oil or grease into the threads of the nuts and wind the bolts int them from the outside of the hull
7, bond the brass strip int the inside of the hull with glass fibre resin and matting (torn up into small pieces)
8, wait a day for the resin to cure and bob's your uncle... i have used this method for abot 20+ years with no problems
I hope this helps and good luck!
