Here goes:
Specifications for the esc, taken direct from Ripmax
Use Boat
Operation Forward/Neutral/Reverse
Break -
On-Resistance 0.003
Frequencyf 4K
Max Peak Current* 940A
Max Continuous Current* 280A
B.E.C No
Input Voltage 6-16 cells
Motor Turn 12-36
One Touch Setting Yes
Temp Cut-off Yes
Water Cooling System Yes
Wire Size 2.5mm2
Case Size 52x35x16mm
Weight 56g
And this is the Graupner 700
Graupner Speed 700BB Turbo Neodym (6306)
High-quality SPEED electric motor with neodymium magnets and a 5-segment dynamically balanced armature. Standard features include ballraces, 1.1 mm thick stator ring and an internal cooling fan. This new motor gives outstanding results in electric racing boats with 12 NC cells for the HYDRO II class using a 39 to 42 mm diameter carbon propeller.
Specification
Nominal voltage 9,6 V
Operating voltage range 7,2-19,2 V
No-load rpm 15750
No-load current drain 2,17 A
Current drain at max. efficiency 15,93 A
Current drain when stalled 117 A
Max. efficiency without gearbox 77 %
Length of case, excl. shaft 66 mm
Diameter 45 mm
Free shaft length 7,5 mm
Shaft diameter 5 mm
Weight 353 g
Part No: G6306
help appreciated!
