Author Topic: Matchbox Kit: Flower Class Corvette PK-901 K80 1/72 scale  (Read 22360 times)
Barrhead
« on: August 30, 2006, 12:16:25 pm »
Hi all!  Is there any interest generally for the above described kit?
Johan
Re: Matchbox Kit: Flower Class Corvette PK-901 K80 1/72 scale
« Reply #1 on: August 30, 2006, 04:35:39 pm »
I'm currently building the Revell re-issue, but I'm interested in a Matchbox version. I'm building the HMCS Snowberry, since the Bluebell option isn't included anymore, unfortunately.
Greetz, Johan
« Reply #2 on: August 30, 2006, 05:50:47 pm »
Considering the number of both Matchbox, Revell etc versions out there, i think you could say that, one event i counted 47 corvettes of which 10% where scratch built or larger scale.
Mine is about 23 years old, others even older, in my opinion one of the best unintentional starter kits.
If you do a search you will find a number of threads dedicated to just this model.
barriew
« Reply #3 on: August 30, 2006, 06:00:00 pm »
We came across someone who had one for sale recently - wanted £40 for it. If you're interested I'll see if I can find the details. He was from the Midlands area.
Barrie
funtimefrankie
« Reply #4 on: August 30, 2006, 06:54:23 pm »
Some on eBay at the moment.
« Reply #5 on: August 30, 2006, 07:38:49 pm »
yea i checked that out, three of them.
Two were revell and one listed as a classic matchbox, though if you wanted to keep it as a collectors piece, i.e. in an unopened state (more valuable) no chance they had everything out of the box, i even went looking for the manuals for mine, still got them from 23 years ago.
Barrhead
« Reply #6 on: August 30, 2006, 08:08:52 pm »
Thank you all for your response to my query which concerns one that I want to sell.  It seems that there is definitely an interest.  I checked out the EBay items and marked two for 'watching' - ie the vintage matchbox kit in USA and one other.  Johan - I sent you a message.
funtimefrankie
« Reply #7 on: August 31, 2006, 07:50:22 pm »
What's the best motor for one of these?
My next project is to finish off mine, which has been on the shelf 80% done, for 15 years!
Johan
« Reply #8 on: August 31, 2006, 08:04:34 pm »
Frankie, mine has a graupner speed 400 motor, with a 1/3 gear. Still going way over scalespeed...
Greetz, Johan
« Reply #9 on: August 31, 2006, 08:12:03 pm »
yes i need to know what motor is best, i have a 6v decaperm which drainds the battery in up to 20 mins, so it needs throwing
ambernblu
« Reply #10 on: August 31, 2006, 08:37:30 pm »
Frankie.. I'm the same as you, and I've decided on a bog standard 385 (5-pole low drain) on probably 6v as I have two or three similar set ups for which I can utilise the same power pack.
Someone else has suggested a Deans Marine Kyte motor but i don't have any experience of these and they are a bit more expensive(!)
I may look at Deans propshafts and props when I'm there tomorrow - though I'm told Propshop is another alternative to source these from.
Cheers, Brian
« Reply #11 on: September 01, 2006, 09:52:56 am »
I got a nice prop shaft with oil filler tube and a brass 3 bladed prop for mine from Deans
        Richard
Kyte motor at £8.95 not that expensive.
« Reply #12 on: September 01, 2006, 02:15:36 pm »
A standard 385 run on about half it's rated voltage and direct drive works well.  Say a 15v version on seven or eight cells.  Mine is currently running on a 12 volt battery and a capstan motor from a dead VHS player.
ambernblu
« Reply #13 on: September 01, 2006, 04:38:55 pm »
Sorry Tricky, you are right, those Kyte motors are good value. I've been to Deans Marine today and picked up two of the bigger motors - £11.50 each. Cheers, Brian
« Reply #14 on: September 01, 2006, 04:58:49 pm »
Brian
You need a spare?
What did you get ,the Kondor?
Let me know how it goes.[Yes I know it goes round]
Good grief I'm getting as bad as some of the others on this forum.
Cheers Richard
ambernblu
« Reply #15 on: September 01, 2006, 05:12:20 pm »
Hi Richard,
Sorry, I'm confusing you now, the two larger motors plus couplings plus props I bought along with (and for) a large Deans Marine model.
I already have a Mabuchi 385 motor set aside for my Revell Flower, but was looking at most of Ron Deans accessories today and was very impressed (especially the 1/100th WWII aircraft kits! Nice :o)
I think I'm going to buy a smaller model next time around and give one of those Kyte motors a go.
Cheers, Brian
ambernblu
« Reply #16 on: September 05, 2006, 07:50:21 am »
Richard, do you know what length propshaft you got for the Revell Corvette? Think you said it was a Deans with an oiler shaft.
Cheers, Brian
« Reply #17 on: September 05, 2006, 08:43:08 am »
Hi there Brian
Yes it was a 6" shaft with oiler tube from Deans cost about £8.50
        Richard
ambernblu
« Reply #18 on: September 05, 2006, 08:57:52 am »
....Cheers Richard.
Just that I was reading an old MM last night about the conversion of the matchbox Corvette kit to R/C and they mentioned an 8" propshaft being used - would it benefit from an extra 2" then (come on guys, don't all shout up at once!  ;D ) or is 6" spot on (as it were?)
Thanks, Brian
(almost felt a poll coming on there - is 6" long enough - YES or NO?  ;D )
« Reply #19 on: September 05, 2006, 11:27:15 am »
Hi Brian
8" propshaft might raise the motor end slightly thereby could help prevent the wet stuff getting in. Very marginal though. I use silicone grease.
Would put the motor right behind stack. Rather cuts down the room for'ard.
Cheers Richard
ambernblu
« Reply #20 on: September 05, 2006, 11:36:28 am »
Richard..
Hi, thanks for your thoughts on that issue - very useful to know the possible plus and minus effects of your choice. I just couldn't make up my mind, but as I use a teflon based grease similar to yours, a 6" propshaft will probably do the job then.  ;)
Cheers and thanks again, Brian
« Reply #21 on: September 05, 2006, 01:40:54 pm »
Hope all goes well Brian
Suppose it will be my fault if it goes pear shaped.
Thank *** I live at the other end of the country.
                                              Richard
ambernblu
« Reply #22 on: September 05, 2006, 01:54:01 pm »
Nah... very much appreciate the feedback - but won't hold you to it!  :D
Hate to admit I forgot to get one when i was Deans on Friday - There was 'I knew there was something else moment'!!  ;D
So I'm planning on chasing the local model shop to see what they had in stock - I may just get one of each - the remainder will come in handy for something in the future no doubt.
Thanks again for the help. Brian
« Reply #23 on: September 05, 2006, 02:10:15 pm »
Agreed about the shaft - mine is an 8" one and restricts the space available for the battery.  When I was using two sticks of four D size NiCads, one each side, and the 385, it didn't really matter.  The thing with the battery is, there's lots of space up front, but the weight of the battery determines the centre of gravity, and can make trimming level awkward.
funtimefrankie
« Reply #24 on: September 05, 2006, 08:03:55 pm »
What should the all up sailing weight of one of these be?
I've read it somewhere, guess it was on the Model Boats forum.
