If it's to fin inside the bulwarks make a good cardboard templat (frostys box) and mark a centreline on the hull so when you transfer it the planking is in the centre and lined up . I use a small block plane if there is only a couple of mill to remove and then a hard block with 120 grit then less sandpaper. I do use scissors on the likes of 1/64 ply or a sharp knife I don't use it on thicker as it can tear or delaminate the ply. if youcan get hold of a ruler that has a strip of rubber underneath to stop moving some have a hard edge, this can be good with a sharp knife and sand to Finnish don't try to get to close to the line with the knife as you only get one in the kits.
Proteus,
