Martin,
Basically that's a YES. Nick has summarised neatly - they are generally comnnected as 2 parallel paths in Laptop batteries, and seen to be Li-ion cells around 1500mah (per cell) with, as nick says quite a low current capability.
I have never found a suspect cell in all the laptop batteries I have eviscerated, but if I did I would either follow nick's advice or dispose of it (carefully and responsibly).
I have, however made several boat packs of two cells in series (2s;1P) so that I had 7V nominal and about 1500 mah capacity and I use these for S400 motors presumably taking a bit less than 10Amps.
This is TOO MUCH to take out of the cells - the voltage sags something terrible so I am abusing them splendidly. This very much confirms the current rating as 2 to 4C maximum
I should have soldered two sets in parallel to get 2S;2P setup (7V, 3000mah)
They would be absolutely ideal for boats where weight and bulk are a problem (grey funnel line, plastic magic, narrow hulls etc) and the current required is not too high, or alternatively where you want a lot of volts or capacity in a hull by making a stack them in series (6S is close to 24 Volts) THINKS - 3 would drive a smoke generator well without needing the weight of a Lead-acid battery
andrew
