hi there
footrails/toerails - the best way I have found of making these is
either from Plasticard or a hard mahogany type of timber - the method I use to produce them is -
My preferred material - Plasticard - must be double the height of the toe rail;
1. Mark the centre line down the full length of the material on the broad side
2. Mark the positions of the openings;
3. I then drill 2 small holes inside the marks for the openings and remove this area with a scalpel so that I am left with an oval shape.
I do this all along the desired length of the toe rail.
4. When I have dressed all the raggy edges off all the holes I have made; I then split the timber down its length
This gives me 2 toe rails - have a look at the scribble below
If you also have a look at the 64 ft Whaleback build in the Masterclass Section of this Forum - although I dont describe how I actually build them - which I should have done
the above is the method which I used.
aye
John e
bluebird
