Author Topic: Battery choice  (Read 1751 times)
Battery choice
« on: September 05, 2006, 11:52:13 am »
What battery choices do people recommend.
What give longest usage?
What gives most power?
Duracell verses Nimh
White Ensign
  • Limits must be limited!
Re: Battery choice
« Reply #1 on: September 05, 2006, 12:02:54 pm »
Tigertiger, it does depend on various technical circumstances. First of all, if you draw high Amps a Nicad or NIMH is definately better as a Lead-battery. Then calculate your maximum weight which you may add to the boat, left for accus or batteries. I.e a Torpedoboat scale 1:100 with an deadweight of about 1,5 Kilogramm it will be difficult to place a lead-battery inside. In this case NIMH is by it`s ratio Weight/capacity first choice. If you have a merchantman, which will draw about 3, 4 Amps and you have some deadweight left of 6 or 8 Kilograms- I think that a lead-battery is much better as you may have more capacity and it is cheaper. The higher the capacity raises- the cheaper lead- batteries will be in their ratio. I.e. just calculate 12V 7,0 Ah Lead Battery to a NIMH-Accuset, 10 cells 7,0 Ah. But if you draw i.e. 15 Amps for the motor, the lead-Battery will break down very shortly. Then a NIMH is first choice.
Do you have any particular example in mind?
Hope this was out of any help.
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
Re: Battery choice
« Reply #2 on: September 05, 2006, 02:26:58 pm »
Tigertiger
You mention duracell v nimh.  The duracell will have a vastly higher capacity, but will be unable to deliver anything like the current of a re-chargeable.  If you are using them for drive power, of the two, nimh every time.  For powering transmitters and receivers, its a matter of personal choice, but I think that after paying for a couple of sets of primary cells, I would look very seriously at re-chargable types, especially knowing my trick of accidentally leaving things switched on...
