Author Topic: Which glue please?  (Read 2769 times)
Bridkid
    • Bridlington Model Boat Society
Which glue please?
« on: November 11, 2008, 12:05:19 pm »
Hi guys.
I have had a search around but can't find the answer to my question...............which is the best glue for sticking white metal fittings to a plastic hull? Also, is there any preparation of surfaces? Someone has told me that there is a special resin but it is very expensive.
Cheers,
Ian.
Stan
Re: Which glue please?
« Reply #1 on: November 11, 2008, 01:02:54 pm »
Hi Bridkid.
I always use superglue  never had any problems. Make sure you clean the white metal well and use a good quality superglue. In my collection of models I have Deans Marine Liberty ship completed 1998  all the fittings are superglued in place  no problems so far.If you have a scrap piece of white metal  try fixing it to plastic card with superglue.
Stan
Kirklees Model Boat club :-)) :-)) :-)) :-))
« Reply #2 on: November 11, 2008, 01:10:05 pm »
I also use superglue , thick Zap-a-gap by Pacer.
I've also used quick set epoxy and that works OK too.
barryfoote
« Reply #3 on: November 11, 2008, 01:19:17 pm »
Lets make thatb unanimous then....Superglue it is....or quick dry epoxy.
Barry
« Reply #4 on: November 11, 2008, 02:27:33 pm »
 Fibreglass to plastic: two-part epoxy (10 min. or 1 hour).
 Plastic to plastic: ordinary plastic solvent (Liquid Poly).
 Whitemetal to whitemetal: two-part epoxy (5min.) or thick superglue.
 Whitemetal to plastic: two-part epoxy or thick superglue.
 Wood to plastic: two-part epoxy, thick superglue or contact adhesive.
 Brass to plastic: R/C Modellers craft glue or thick superglue.
 Rubber Fender: contact adhesive (UHU, Bostik).
 Window glazing: R/C Modellers craft glue.
http://www.modelslipway.com/hintsnTips/hints.shtml
Bridkid
« Reply #5 on: November 11, 2008, 07:00:29 pm »
Thanks guys, I have both so will try each one in turn and see which I prefer.
Cheers,
Ian.
Philipsparker
« Reply #6 on: November 12, 2008, 08:44:46 am »
Me too. Zap-a-gap every time although I prefer the medium (green bottle) version.
Phil
StarLocAdhesives/FiveStar
« Reply #7 on: November 12, 2008, 07:38:11 pm »
I would use CA glue, but i would go for the flexy cyano , impact toughened with a synthetic rubber in the formulation to give higher strength so less chance of small heavy items (for there size) coming off
« Reply #8 on: November 12, 2008, 09:22:09 pm »
Having just found the wonders of cyno (and no longer sticking myself together) I would go down the CA route. Also thanks to you DickyD for now giving me a list of what sticks what, as in the past I've only ever built wooden power boats (plus a few springers)but I'm now branching into a bit of scale. At least now I know it won't all fall to bits
andyn
« Reply #9 on: November 13, 2008, 05:20:06 pm »
I second the Zap-A-Gap idea, also Slo-Zap is very good, and some stuff with a red cap I got off ModelPower at llanberis is good stuff too, even though the nozzle has broken off and I now have to use a toothpick.
I will never buy a bottle of thin cyano again, it's stuck me to other parts of me far too many times, and has ruined many a good model.
I did once stick both hands together, and not being one to go to hospital and not having heard of superglue debonder, I decided to remove the hands from each other with a X-Acto blade between my teeth....
Page created in 0.097 seconds with 21 queries.
