Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15   Go Down
Author Topic: Sir Lancelot the Building from Jan09  (Read 157182 times)
wallace
Re: Sir Lancelot the Building from Jan09
« Reply #225 on: February 21, 2010, 04:23:50 pm »
Theses photo's are the making well my making of the small boat stays to keep the small boat in place when at sea.
I first used a 3mm nylon twine cut with a hot knife and the ends  whipped sealed with a hot knife again. :-)) :-))
wallace
« Reply #226 on: February 21, 2010, 04:26:04 pm »
photos of how the stays look on the small boat
wallace
« Reply #227 on: February 21, 2010, 04:30:36 pm »
Re-done the stays I was not happy with the ones I had done this time I made them out of 2mm thin nlyon cord
done them the same way but they look alot better. %) :-)) :-)) :-))  wallace
dan
« Reply #228 on: February 23, 2010, 09:57:14 pm »
hi wallace,
 ive been away for a while and just caugt up with the build. its come on a long way since i last saw it and its looking fantastic. how much longer do you think itll be befor you have it on the water? keep the pics coming mate  :-))
wallace
« Reply #229 on: February 27, 2010, 04:13:44 pm »
Some more of the build small boat painted just needs a touch up then onto the boat deck she goes.
All the photos are showing boats depth chargers etc  just sitting on the Sir Lancelot  just wanted to see how they are looking and what more I can do to them the boat stays I'm going to re-do when I get the eye bolts at the show next week-end from mountfleet  if you go back to the big gun at the front you will see the deck eye bolt that I used there I like them so have ordered 20 to used around the deck.
                               :-)) :-)) :-)) wallace  :-)) :-))
wallace
« Reply #230 on: February 27, 2010, 04:17:45 pm »
more off the fitting
wallace
« Reply #231 on: February 27, 2010, 04:20:35 pm »
All about the stern area
wallace
« Reply #232 on: March 01, 2010, 05:05:13 pm »
Theses photo's are about the small bits on the boat but still have to be done.
They are the Large Rigging Screws for the lines from the main mast to the bow
The small rigging screws for more lines
And the nuts and bolts to fix the gallows to the deck
All have been cleaned and small bits taken off I have painted them with three coats of primmer
I know they are boring but got to be done. :-)) :-)) :-))
wallace
« Reply #233 on: March 12, 2010, 04:02:55 pm »
  :-))   Hi once again well after a short break from doing abit on the boat  I did go to the show over the w/e last had a great time.
This photo is about the way i'm going to do my ladders they are made from wood i'm thinking of staining them and coating in varnish I will put them together with the ones I have done out of white metal to see which ones I like.
wallace
« Reply #234 on: March 17, 2010, 06:49:49 pm »
up date on things over the past weeks still doing all the small bits and the photos here are about the fittings that hold the gallows to the deck these are the nuts and bolts.
Also a re-do of the lifebelt locker was not happy with the first one, and other  parts are the Oropesa float cranes took them out of container that was holding all jobs done and after looking at them both once again was not happy with the paint so to day rub them down with 500 grade paper and re-painted then hope ok for tomorrow when i will put the cord to the cranes etc and get ready to fit them onto the boat. Also have painted well primed the eye bolts will top coat over the next few days. :-)) :-)) :-))
wallace
« Reply #235 on: March 19, 2010, 04:53:28 pm »
Todays photos are still about the small bit and some of the lockers,with the lockers which I done during the winter months before xmas had a look at them today and did not like them so I have rub them all down with 800 grade paper and re-painted them so far they look alot better will leave them to harden off and tomorrow will add the bits to them  :-)) :-)) :-)) :-))
wallace
« Reply #236 on: March 20, 2010, 03:55:59 pm »
These are the lockers in front of the bridge all done and two lockers each side of the stern gun mounting
Have put the line onto the two Oropesa float cranes just got to put the hocks on and to fix to the stern
Once I have got the lights all fitted inside and outside I will start putting everything together.
                        Hope you like  :-)) :-)) :-))
wallace
« Reply #237 on: April 06, 2010, 04:29:10 pm »
The stern area with the depth charges nearly all done only abit to do.
wallace
« Reply #238 on: April 06, 2010, 04:33:28 pm »
Theses are the ladders on the side of the bridge and also up to the searchlight got to cut them to size they are 13mm wide Im going to stain them before I fix them.
wallace
« Reply #239 on: April 06, 2010, 04:36:57 pm »
This ladder is going to be fixed to the side of the bridge.
wallace
« Reply #240 on: April 06, 2010, 04:41:26 pm »
Ladders to get onto the frwd deck from the main deck they are 22mm wide and will be cut to fit
wallace
« Reply #241 on: April 06, 2010, 04:44:02 pm »
Just let you see the name plate and where its going to be fix you will see it and it will stand out when all done. :-))
wallace
« Reply #242 on: May 04, 2010, 07:13:46 pm »
Sorry its been well over a month since I last posted anything but what with all things going on with my body I have not done much to the boat.
Well I let my boat out of my sight for the past 4 days  to a great person who is a good member of Ellesmere Port model Boat Club as I'm no good at doing working lights.
So these photos are the working lights on the Sir Lancelot and what a job my friend has done at the moment alot of the fittings are still not clued down I cannot thank him enough thank you S
Lights done on the f/ward portholes
port/stbd lights
wheelhouse
engine room
cabin under bridge
searchlight
overtaking light
The mast head light is to be done later need the very thin wire to run up the mast
wallace
« Reply #243 on: May 04, 2010, 07:16:23 pm »
A few more shots of the lights
wallace
« Reply #244 on: May 04, 2010, 07:22:36 pm »
View of the searchlight and a view from the bow
wallace
« Reply #245 on: May 14, 2010, 07:05:36 pm »
 :-))  Hi heres a update on the build since the lighting has been done I have fixed the searchlight all together.
have also fixed together the upper bridge and lower bridge all together to the superstruct its all looking good
will have to do some more on the boat but have been doing alot around the home as over the past 4 years its been all boats so get the house all painted inside etc it should last for another 4 years sailing.
dan
« Reply #246 on: May 14, 2010, 11:09:41 pm »
looking good wallace  :-)) not long until it will be going on the wet stuff?
wallace
« Reply #247 on: May 28, 2010, 06:56:56 pm »
Back in the mood for building again  so these photo taken this afternoon  28/5/10 in the lovely sunshine.
The photos are the building up of the main deck the main mast has been pin and also 4 holes drilled into the deck to take the brass nuts and bolts so the mast can be removed for transporting to lake its been done that way as the mast head light the wires will run down both sides of the mast and under the deck to join up with all the other wires Im thinking now about putting lights into the companionways and the raised skylight behide the mast.
The photos show most of the fitting fixed to the deck only a few not done.
   (Would welcome any comments about it)
wallace
« Reply #248 on: May 28, 2010, 07:09:16 pm »
Here's a few more of what I have done today.  :-)) :-)) :-)) :-)) :-)) :-)) :-))
Paul Godfrey
« Reply #249 on: May 31, 2010, 09:21:31 pm »
Hi Wallace,
Firstly, apologies for not posting previously on your build log - as you know, I've been following the build with much interest, and must say that you are doing a super job. I can't wait to see the finished boat on the water (shouldn't be too long now!!??).
I think we agree that the white-metal stanchions are a little fragile (as mentioned in the latest posting of my build), and the brass items you have used instead look the business. You've done a great job of the railings too.
I see that you have recently been adding items to the front section of the main deck, and notice that (like me) you've had to trim the printed deck overlay, as it's a bit too wide to fit between the bulwark supports!! I've painted the doors to the companionways grey, but looking at yours which you've varnished/stained, I wish in hindsight that I'd done the same - they look much better.
The lights that a friend has done for you look very good indeed - they certainly add that extra touch to any boat.
Keep up the great work Wallace, I'll be looking in regularly!
Best wishes, Paul
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15   Go Up
Page created in 0.015 seconds with 18 queries.
