Hi to you at so many miles away hello Derek yes the hull is gloss that is due to I was in the Royal Navy for 12 years in the seamenship branch and have painted so many ship sides and all the ones I painted well help paint were all gloss paint and the paint I have used is the true colour paint for the R.N But anyway derek many thanks for your kind words.
Here are a few more photos of the build and these photo are showing you the big mistake I made with the f/ward port holes on the stbd side.
I was fixing the pennant number T228 to the port side and it just went on below the port holes.
Went to do the same on the stbd side and there was no room to fix the pennant number,so the photos show port holes remove ,
the two holes open up in the correct postion, and the pennant number fix by blue tack so I could make the holes in the right place and the 3rd photo shows how it should look from the port side.
Will fill the the old part of holes with f/glass tomorrow leave to go off rub down and file the hole to the right size in the right place.Then re-paint with primmer ,undercoat then top coat Im sure all will look good when done hope to have it done by next week some time
I have always said if im not happy I do it again well this is the biggest mistake as yet,
wallace
