Second trial run completed with:
21T bell motor* fitted to satsuma ply bulkhead. This was made as a pattern in cardboard, cut in satsuma ply, then the motor fitted with a rigid tube to the prop shaft and the radial motor mount position marked.
Bulkhead position marked
The bulkhead was then hot-melted to position and the motor and coupling fitted
I howked out the flotation foam in the bow of the boat to enable me to get the battery well forward.
*If the motor had numbers it would be something like a 2508/21, 1200Kv
Bench trials showed good controllabiility, and, it seemed, modest revs.
Trial flotation and power blips in the garden pond showed that would launch itself right out of the pond EVERY TIME
Canal trials then followed - performance (and attitude in the water) very similar to the first tests despite the forward battery weight
Up on her hind legs like a politician
Bow wave "wings" going sideways beautifully
Speed seemed the same as before - but with the forward battery position sharp turns at speed had the potential to turn her over
Conclusion: Good trials, Wrong boat, both these motors showed the promise of making the right boat interestingly quick, if I can stop the bows from climbing!
I am going to return the hull to being a footy yacht, and make a replacement trial hull. (or two)
Has anyone played with the Slingshot boat - especially the hull? I suspect that it would be quite fun with this power-train fitted
I also can't wait to see how AndyN's boat goes with the Feigao inrunner - I have a sneaking suspicion it will need a small high-speed prop! This is the kind of motor I would stick in a Ducted fan or waterjet! Now there is an idea!
andrew
