Author Topic: Which glue?  (Read 1484 times)
RODDERS
Which glue?
« on: November 20, 2008, 10:24:44 PM »
Hi All
  I'm using super glue for sticking of superstructure(plasticard/aly/card etc) BUT I'm finding that it tends to leave a white "smokey" residue if I stick clear plastic,or indeed anything with a shiny surface. Im sure you guys will know what the best stuff is to use to prevent the white marks?
   Thanx in advance..Rod
maninthestreet
Re: Which glue?
« Reply #1 on: November 20, 2008, 11:29:46 PM »
Polystyrene cement (in the liquid form with a brush) is the normally recommended for plasticard.
Avoid superglue for use with clear/shiny plastic - try R/C Modellers Glue from Deluxe Materials:
http://www.deluxematerials.com/boatmodelling.html
walktheplank
Re: Which glue?
« Reply #2 on: November 21, 2008, 10:13:27 AM »
maninthestreet is right, dont use super glue. I use a Plastic weld for Styrene, ABS, etc,  But for clear try a Canopy glue as this does not leave any Smokey fumes. sonic.
barriew
Re: Which glue?
« Reply #3 on: November 21, 2008, 11:31:01 AM »
You can remove most of the smokey residue from clear plastic with meths. It is also possible to buy super glue which will not cause this effect
Barrie
StarLocAdhesives/FiveStar
Re: Which glue?
« Reply #4 on: November 21, 2008, 07:03:37 PM »
If using a superglue type, use an odourless cyanoacrylate, they dont fog windows as they give off no vapour, for non superglue type a canopy glue is best.
RODDERS
Re: Which glue?
« Reply #5 on: November 22, 2008, 06:25:05 PM »
Thanx guys,I knew youd have some ideas!
