April 19, 2024, 10:55:46 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Glue etc.
Which glue?
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Which glue? (Read 2154 times)
RODDERS
Guest
Which glue?
on:
November 20, 2008, 10:24:44 pm »
Hi All
I'm using super glue for sticking of superstructure(plasticard/aly/card etc) BUT I'm finding that it tends to leave a white "smokey" residue if I stick clear plastic,or indeed anything with a shiny surface. Im sure you guys will know what the best stuff is to use to prevent the white marks?
Thanx in advance..Rod
maninthestreet
Full Mayhemer
Offline
Re: Which glue?
Reply #1 on:
November 20, 2008, 11:29:46 pm »
Polystyrene cement (in the liquid form with a brush) is the normally recommended for plasticard.
Avoid superglue for use with clear/shiny plastic - try R/C Modellers Glue from Deluxe Materials:
http://www.deluxematerials.com/boatmodelling.html
walktheplank
Guest
Re: Which glue?
Reply #2 on:
November 21, 2008, 10:13:27 am »
maninthestreet is right, dont use super glue. I use a Plastic weld for Styrene, ABS, etc, But for clear try a Canopy glue as this does not leave any Smokey fumes. sonic.
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: Which glue?
Reply #3 on:
November 21, 2008, 11:31:01 am »
You can remove most of the smokey residue from clear plastic with meths. It is also possible to buy super glue which will not cause this effect
Barrie
StarLocAdhesives/FiveStar
Guest
Re: Which glue?
Reply #4 on:
November 21, 2008, 07:03:37 pm »
If using a superglue type, use an odourless cyanoacrylate, they dont fog windows as they give off no vapour, for non superglue type a canopy glue is best.
RODDERS
Guest
Re: Which glue?
Reply #5 on:
November 22, 2008, 06:25:05 pm »
Thanx guys,I knew youd have some ideas!
Print
Pages: [
1
Go Up
« previous
next »
Glue etc.
Which glue?
