Model Boat Mayhem - Forum
Author Topic: Crane barge - Owners Model  (Read 8846 times)
Umi_Ryuzuki
« on: November 23, 2008, 06:19:09 AM »
I built this model for Manson Construction. The model was commissioned by the
builders, Gunderson Marine, in appreciation for being given the opportunity to
construct the barge for Manson.  The model took ten weeks to build.
I built up the barge and crane while an associate built up the
accomodation house and helipad. The railings really pushed the limit of
my ablity to do brass etching. The crane boom is stick built in styrene.
The barge, E.P. Paup, will be towed to Louisiana and fitted with the deckhouses and crane.
It will then work in the Gulf area building or recovering oil rig equipment.
banjo
Re: Crane barge - Owners Model
« Reply #1 on: November 23, 2008, 05:21:24 PM »
I saw this post earlier this morning....
I cannot let it pass uncommented
OUTSTANDING!
Bunkerbarge
« Reply #2 on: November 23, 2008, 06:10:08 PM »
Absolutely stunning model.  Very many thanks for sharing it with us.
« Reply #3 on: November 23, 2008, 06:20:48 PM »
WOW  :-)) :-))
Martin [Admin]
« Reply #4 on: November 23, 2008, 06:31:19 PM »
  Great model Umi.... those scale people on launch day are fantastic!!!   ok2
boatmadman
« Reply #5 on: November 23, 2008, 06:37:22 PM »
Fantastic Umi, which one is you?
Umi_Ryuzuki
« Reply #6 on: November 23, 2008, 06:39:09 PM »
I am the one behind the camera,... Always behind the scenes... always.. ok2
« Reply #7 on: November 23, 2008, 08:26:36 PM »
Really nice Umi, don't worry fame  will find you (best leave an address though)  :}
cos918
« Reply #8 on: November 23, 2008, 08:31:50 PM »
hi umi That is one top build. :-)) i wish i had half of your skill. can you give us an insight in to how you go about building some like this. Ie were do you start get the info off the plan turning it in to that crane jib. My self i would not know were to start. so any rips from a master is alls ways welcome.
john
« Reply #9 on: November 23, 2008, 08:42:16 PM »
Absolutely superb model Umi
Umi_Ryuzuki
« Reply #10 on: November 24, 2008, 01:36:56 AM »
john
Thank you, everyone...
The boom drawings gave me two views.
I built up alternate sides by laying the pieces on the plans. and setting all the perpendicular cross bars.
I then worked the cross bracing back in. The color map shows which sides of each area were built first.
Once each area was done, the spacing was for the adjacent sides is set by the previous of following section.
When the sections are joined, again started laying in the perpendicular bars, and followed up with the cross bracing.
Very much like an airplane wing build.
cos918
« Reply #11 on: November 24, 2008, 11:21:57 AM »
thanks umi now you have shown the pan in color and explained it it starts to become clearer .
john
rathikrishna
« Reply #12 on: January 18, 2011, 12:25:43 PM »
Good evening Umi...will it works..?  means the crane..?  its superb indeed..
unbuiltnautilus
« Reply #13 on: January 18, 2011, 03:54:11 PM »
Excellent, now THAT is what I call a Crane Barge! Superb work on the jib, patience is obviously a virtue :-))
Umi_Ryuzuki
« Reply #14 on: January 18, 2011, 07:53:15 PM »
Thank you for the compliments.  :-)
This model was built for static display, so nothing operates, and it will never see the water.
The following models, however, were built to create a towing event and used working cranes.
The first event was the Belgian "crane and pin" competition done by the Modelbouwvrienden Hofstade, Belgium.
Many pictures were posted by the Mailline Vaargrouep, Netherlands, in 2009.
 CRANE AND PIN EVENT 2009, Modelbouwvrienden Hofstade, Belgium.
The Belgian event required two or more tugs to line up the "windmill foundation" over a steel pin.
For our event  I built a similar crane, however we required the tugs to maneuver the crane
 so that the "transformer module" could be placed onto the offshore platform.
Here are a few shots of the working shearleg crane barge model in use, and the offshore spar platform.
Offshore marine heavy lift shearleg crane barge model
rathikrishna
« Reply #15 on: January 19, 2011, 04:44:17 AM »
Oh my god..Umi..its far beyond imagination..will you tell me the working priciples of those cranes..? because i am already working on a crane for recovering my crafts..please..?
Umi_Ryuzuki
« Reply #16 on: January 19, 2011, 05:50:24 AM »
It is very simple, and something you can easily duplicate.
The Belgian crane is just a gear motor and winch, used to deploy or take in line to lower or lift the "foundation".
My crane is a gear motor on a double winch, they deploy or take in line to the pulleys.
More loops through more pulleys make the lift slower, but make the winch able to lift larger loads.
This is called a block and tackle.
http://www.globalsecurity.org/military/library/policy/army/fm/55-17/ch6.htm
The same principle applys to suspending the crane boom.
Here is a picture of the winch.
rathikrishna
« Reply #17 on: January 19, 2011, 10:45:47 AM »
Wow..great..and thank you for the link...may i save the picture from you..?  please...
rathikrishna
« Reply #18 on: January 19, 2011, 10:49:47 AM »
Umi..a million thanks for the links..i was looking for one...and now its not time to read, so i converted in to a word file, so i can simply read at home...thanks once again..you are so informative...with lots of respect...
Umi_Ryuzuki
« Reply #19 on: January 19, 2011, 07:22:40 PM »
Yes you may...  :-)
