Author Topic: SLA terminals and solder  (Read 19673 times)
Re: SLA terminals and solder
« Reply #25 on: November 25, 2008, 08:58:02 pm »
I've got one of those Maplins crimpers. It's great, my hair has never looked better..... :}
Capt. Spaulding
  • Hurray for Captain Spaulding, the African explorer
« Reply #26 on: November 25, 2008, 09:04:57 pm »
Gentlemen, gentlemen, now, please...
Good. Now that that's settled, here's what I decided to do. I have crimped (which, unfortunately, I can't say in Latin). And not only that, but I used a semi-proper crimping tool that I just happened to have in the workroom. I say semi-proper, because I think that it was designed for crimping co-ax cable. But it worked very well with the spade connector, mashing the metal and plastic to a pleasing, efficient shape with minimal effort. Current is flowing from battery to ESC, as it should. On to the next step..getting out the d---ed soldering iron and attaching some capacitors the motor.
Thanks again to all who contributed to this thread.
Cheers,
Capt. Spaulding
OMK
« Reply #27 on: November 25, 2008, 09:30:41 pm »
Craplins?
CRAPLINS???
Mate, you're a man of God; you can't go round saying things like Craplins!...
Hehee... nice one!... right up there with Colin Bish's witty retort!
Peter Fitness
« Reply #28 on: November 25, 2008, 09:55:20 pm »
There are 3 things to remember when soldering........cleanliness, cleanliness and cleanliness  O0
Faraday's Cage, you say if the wires are soldered to the battery, then removal requires snipping - not if you use Deans plugs, as shown in my earlier post. The pins on Deans connectors are spring loaded, gold plated, and provide an absolutely positive connection. By standardising on them, I can easily and quickly interchange batteries, motors and ESCs between any of my boats
Peter.
« Reply #29 on: November 25, 2008, 10:19:01 pm »
OH FLJ even I have a ratchet crimper O0
andygh
« Reply #30 on: November 25, 2008, 10:59:05 pm »
I soldered up to forty-five-thousand-million in a single day, every day, in offices all across the rathole town of Bridgwater.
Then I found a proper job.
 {-) I can imagine  {-)
OMK
« Reply #31 on: November 25, 2008, 11:19:17 pm »
Captain S., so now that you're in business with the crimps, you've still got me intrigued. If I'm not being nosy, why did you prefer to solder the terminals in the first place? You mentioned about it making for a more convenient wiring plan.
Capt. Spaulding
« Reply #32 on: November 26, 2008, 02:37:25 am »
PMK:
Not nosy at all. My thinking about "convenience" ran something like this: rather than use a quick-release connector or some other device at the battery terminal, why not skip a step and solder directly to the terminal itself? But, it seemed reasonable to wonder, would the heat of the soldering process damage the battery? The more I thought about it, the more I wanted to know the answer -- curiosity, you might say, knowledge for the sake knowledge.  That's why I asked the brethren here at MBM.
Why did I finally decide to use quick-release crimp connectors? I had them in my tool box, I had the crimping tool, and I was concerned that my poor soldering skills would result in a dead battery fit only for use as a weight.
Mr. Fitness:
re Dean's connectors: I used a pair between the motor and the ESC. It was the first time I have put them into a boat, and I'm quite impressed with them. A very high-quality product. (Yes, I did have to do some soldering. The joints are gnarled and ugly, but they'll serve. And that heat-shrink tubing covers a multitude of sins.)
Cheers,
Capt. Spaulding
« Reply #33 on: November 26, 2008, 03:33:00 am »
Just a word of caution, if soldering any battery direct into a circuit, make sure you have 'quick pull'
fuse's, isolators etc, that can be quickly pulled in case of a problem! You don't want to be scrambling
about for wire cutters, pliers, knife, etc when smoke is coming from somewhere in the bowels of your boat!
Peter Fitness
« Reply #34 on: November 26, 2008, 04:49:32 am »
Mr. Fitness:
  Mr Fitness???  :o :o he was my father  :} :} We're not that formal here Capt S. (or at least, I'm not)  :-)
Peter.
Peter Fitness
« Reply #35 on: November 26, 2008, 04:52:18 am »
fusees, isolators etc, that can be quickly pulled in case of a problem! You don't want to be scrambling
Martin, precisely the reason why I use Deans connectors.
Peter.
« Reply #36 on: November 26, 2008, 10:23:15 am »
And sometimes you will get a straight answer, quite often in fact. But sometimes.........
barriew
« Reply #37 on: November 26, 2008, 10:26:12 am »
............. a simple question will generate several hundred different solutions %%
Barrie
andygh
« Reply #38 on: November 26, 2008, 04:13:42 pm »
There's always something useful in amongst them though  ok2
