Author Topic: Green Windows?  (Read 7086 times)
tonyH
Green Windows?
« on: September 13, 2006, 09:42:36 pm »
Has anyone a source of green transparent plastic sheet approx 1mm thick for windows. It would appear that butyrate is the right thing as used for drawing templates etc. but I can't find a supplier of the material itself.
The wheelhouse is like a small greenhouse (no pun intended) and the model is at 1:12, so using a paint or ink finish on clear could stick out like a sore thumb.
Any ideas please?
Tony
MikeK
  • Utter Bloody Chaos !!
Re: Green Windows?
« Reply #1 on: September 14, 2006, 08:13:50 am »
Maybe trawling the school section of supermarkets/Woolies etc might turn up cheap set squares and the like that could be sacrificed. ??
MikeK
Voyager
Re: Green Windows?
« Reply #2 on: September 14, 2006, 10:00:25 am »
If you don't mind spending your money, then you could try asking for gelatine filters in a camera shop, expensive for what you want, but would do the job.
Voyager.
Roger in France
Re: Green Windows?
« Reply #3 on: September 14, 2006, 02:01:14 pm »
Try "Badoit" French Mineral Water bottles which are green tinted plastic. I presume you only need small areas so the curvature of the bottles should not be a problem. The bottles, as sold here in France, do not have any printing on them, merely a printed, tight sleeve which is slipped over the bottle.
The water is available in UK supermarkets. But if you have a problem finding it I will cut a bottle up and send it to you, on request.
Roger in France.
tonyH
Re: Green Windows?
« Reply #4 on: September 14, 2006, 02:35:04 pm »
Thanks to all for the ideas sofar. Rogers idea got me thinking (at last). Each window (14 in all) is approx 50mm x 50mm so not small enough to ignore the curvature BUT has anyone tried softening and flattening sections from 'pop' bottles in the oven? 7UP bottles are not far away from the colour and the contents aren't too bad mixed with Genever!
Tony
maninthestreet
Re: Green Windows?
« Reply #5 on: September 14, 2006, 04:07:30 pm »
JP Perkins list green transparent plastic sheets on their website, but only 0.23MM think.
How about using clear plastic sheet, and buying a green indelible marker pen to colour them?
flag-d
Re: Green Windows?
« Reply #6 on: September 15, 2006, 11:32:23 pm »
How about lighting filters as used for stage lights etc?  Try a local theatre or similar venue.  Possibly Maplins might have something for their disco lighting and they're usually good value.
tonyH
Re: Green Windows?
« Reply #7 on: September 16, 2006, 10:14:38 pm »
Hi All,
Thanks for the thought on theatre gels, Mike, but they are generally too thin (Part time theatre techie!).
Thanks also MisT but I found that I couldn't get consistent with the marker over the size of window required.
HOWEVER, the 7uP system seems to work.
I checked with Delia and sandwiched the offcuts from the bottle between silicone baking parchment and then between 1/8 brass sheets. 10mins at 150ish (Regulo?). The pieces came out flat and stayed flat. The bonus was that they shrank by about 30% and thickened from 0.3mm to 0.5mm which is stiff enough for the windows.
So it would seem that green (7uP), brown (Shandy) and other colours are freely available.
Tony
boatmadman
Re: Green Windows?
« Reply #8 on: September 16, 2006, 11:46:28 pm »
how about green cellophane? Dunno where to get it though!  ???
Subculture
    • Dive-in to Model submarines
Re: Green Windows?
« Reply #9 on: September 18, 2006, 01:12:14 pm »
EMA's do polycarbonate green tinted sheet-
http://www.ema-models.co.uk/shop/prodpages/page-POLY-500G.html
These guys also do an exhaustive range of modelling materials, including tinted sheet-
http://www.modelshop.co.uk/
Finally, if you want to straighten out plastic sheet, you can use a heat gun (carefully) or clip it on a flat board in your oven for a while at a high temperature.
wombat
Re: Green Windows?
« Reply #10 on: September 18, 2006, 06:47:36 pm »
As an alternative, hows about printing onto inkjet film - you can then choose whatever colour you want. To thicken it, perhaps you could laminate it or bond it onto perspex. - maybe worth a couple of experiments.
Hmmm, could be a way of doing glazing bars.....
Tim the Wombat
tonyH
Re: Green Windows?
« Reply #11 on: September 18, 2006, 09:16:23 pm »
Thanks all,
As I mentioned above, the 7uP bottle plastic works well in the oven and is free.
I'll get a sheet of the polycarbonate from EMA as well (Brilliant Site - Thanks SubC) to check for colour but it's been fun trying to resolve this one.
Now - All I want is a scarlet rubberised paint that will stick onto latex.
No.........
Tony H
Subculture
Re: Green Windows?
« Reply #12 on: September 18, 2006, 09:46:55 pm »
There is a paint called psycho paint made by Smooth-on. It's designed to stick to silicone rubber, so not sure if it's suitable for latex, but if you email Smooth-on, they'll advise you.
http://www.smooth-on.com/psycho%5Fpaint.htm
MikeK
Re: Green Windows?
« Reply #13 on: September 19, 2006, 07:41:27 am »
No.........
Tony H
Off to a fancy dress ball are we, Tony ?? ;) ;)
MikeK
tonyH
Re: Green Windows?
« Reply #14 on: September 19, 2006, 10:22:17 am »
Nudge, Nudge, Say no more!!
I learnt my style from Buster Crabb (Allegedly)
Doc
Re: Green Windows?
« Reply #15 on: September 19, 2006, 02:47:23 pm »
Try looking in the school supplys section of stores.  There are a number of transparant plastic folders for notebook paper.  Not exactly the 'stiffest' plastic around but you should be able to find green ones.
 - 'Doc
