Hi Oldiron,
and thanks for your comment. I noticed your post after I had painted the deck otherwise I would have used the original color scheme like you did. By the way, your boat looks great!!!
I use a Robbie 12V gear motor (EF 76 II) and a four bladed 60mm brass prop. It will be equipped with lights, rotating radar screens and a ram sound module (horn # 82). The battery is a hugh 12V 17Ah mounted close to the bottom. This will help with the ballast, but it still needs more weight towards the stern. When it is finished I will post a few pictures also from inside the hull. Do you know of anything else I should take into consideration or do you have additional information from Wijsmuller? Oh, I replaced all the copper wire with steel guitar wire, so everything is nice and straight.
Wilhelm
