...Well Done Ship Mate...
I have some wee 3 volt motors with a Right angled worm drive onto a straight through 2 ended shaft...I could send you one & try it to see if it would drive the Paddles as well as the Prop...If you want to try it P.M. me your Addy...
And Dont Forget the Traditional Scottish Music Bellowing out of the Lounges on Board...I can help you with that too also as well...
Once Again...Well Done... Or as they say on the Banks of The Clyde..."Its Pure Dead Brilliant By The Way"
...Best Regards...Norry...
Thanks Norry, I'm glad you like her.
With regards the paddle drive, I have been working on it today. Had to cut it short when I was testing the system and caught my finger. Good job the hull was red !!!
The single motor idea might have to be scrapped as it tended to wobble a bit. Everything has to be mechanically true, and this is proving to be a problem. I was running the wheels, before fixing down the motor, to find the best position, but there was none that ran smooth.
I like the music idea, but, one thing at a time eh!... might be ready for 'Yuletide music' time.
ken
ps
How do you run 3 volt motors on a 6 volt battery at 3 amps or more ?
I only ask because I rigged up some heavy resistors to allow mine to run slow as a test.
