Author Topic: Glue and water question  (Read 3685 times)
« on: December 10, 2008, 09:55:28 am »
Is Cascamite waterproof?
Has anyone used contact adhesive below the waterline?
If yes, did you have any problems with it?
Liverbudgie2
Re: Glue and water question
« Reply #1 on: December 10, 2008, 10:16:27 am »
Cascamite is waterproof however  would suggest using an alfactic white glue which both cheaper to buy and easier to use. This is available at most timber yards, at least in the UK, and major DIY chains as well I expect.
LB
« Reply #2 on: December 10, 2008, 10:21:11 am »
Thanks for the quick response LB.
I have cascamite, and have been unable to find alypahtic glue here (China). So I am trying to work with what I have at hand.
« Reply #3 on: December 10, 2008, 11:28:52 am »
It always was Tiger, mix a drop of Meths in amongst, it gets rid of the air bubbles.
   Regards   Ian.
« Reply #4 on: December 10, 2008, 12:06:13 pm »
FleaBay Item number: 360112470588  or 370126224582
« Reply #5 on: December 10, 2008, 07:19:21 pm »
Dad (now 90) built me a couple of models in the 50's using cascamite. They are still around although not been sailed recently. Never had a leak or any other strength problem.
HTH
Doug
minnjoe
« Reply #6 on: December 23, 2008, 01:22:44 am »
I have used Contact Cement on several boats below the water.  They were double planked boats and the top plank was held in place with Contact Cement.  I applied cement to the base plank and the top plank, let dry for 30 seconds and then put the top plank in place.  Place it carefully because you won't be able to move the plank.  Remove any excess cement.  The hull was then covered with 2 oz fiberglass material and finished with polyurethane, sanded and polished.
Page created in 0.097 seconds with 22 queries.
