Author Topic: SLA  (Read 2009 times)
packy46
SLA
« on: December 16, 2008, 02:13:25 am »
Hello:
An SLA with a rating of 12 v/7ah , using 2x motors , at 3 amps each max , should run approx 1.1 hrs , at full speed,probably won't do
full speed for an hour- anyway , is thats right , Now I see on the battery picture on line , initial current / and cycle current,(2.7 / 3.6 max.) does this mean recharge rate?.
Need help
Tim
 :embarrassed:
Weeds
Re: SLA
« Reply #1 on: December 16, 2008, 04:09:32 am »
i can't help you.. maybe check on my site.. other than that, im sure toesup and the crew will jump right on your case! :) http://rcgearing.com/boats.html
the vac-u-tug 545 motors should give you plenty of power and low amps (less than one amp) as they can run anywhere from 6-7 volts to like 24 volts i imagine..
why do you think your motors pull 3amps?
FullLeatherJacket
Re: SLA
« Reply #2 on: December 16, 2008, 10:58:57 am »
Packy
Not a local supplier for you, but you might find this link useful.
http://www.component-shop.co.uk/html/lead_acid.html
The chargers are of Chinese origin (I think), so you should be able to find some very much like these on US hobby stores/battery suppliers' websites.
FLJ
packy46
Re: SLA
« Reply #3 on: December 16, 2008, 05:35:05 pm »
OK Thanks :
Getting closer,found some pretty good info from your post.
Thanks All.
Tim
Page created in 0.025 seconds with 19 queries.
