Author Topic: bilge pumps  (Read 2246 times)
paddysdad
bilge pumps
« on: December 29, 2008, 10:53:34 am »
HI.Where can i buy in the UK a 12v Bilge pump.Looked on the internet no luck so far.Regards Paddysdad
Re: bilge pumps
« Reply #1 on: December 29, 2008, 11:35:33 am »
Hi all...not sure ....but if for a model application 'paddysdad'....in OZ we would just go to an Auto supplier for a replacement windscreen washer pump.....they come in two versions...both of which are 12 Vdc
1) the gear type version ...[technically positive displacement]
2) the impeller type version...[could better if you have a fast filling leaking boat]
The latter is not intended as a joke...just think about it
regards Derek  :-))
FullLeatherJacket
wideawake
Re: bilge pumps
« Reply #3 on: December 29, 2008, 02:30:51 pm »
http://www.jabscoshop.com/article.asp?ls=&v=CE3D7FD4FE2242C49619E0A929EB8B9F&override=1&title=jabscoshop%3A-About+Submersible+Pumps
Very popular with the Bait Boat Boys.
....and with inland waterways boats.  You can get them at any inland waterway chandlery.  Several of them have an on-line pesence as well.   Just one example is Midland Chandlers
www.midlandchandlers.co.uk
they also have several branches.
HTH
Guy
Re: bilge pumps
« Reply #4 on: January 06, 2009, 06:40:46 pm »
I just put " bilge pump " into my search engine (google) and the very first find was
http://www.boatersland.com/nobipu.html
plumbing, bilge pumps, non-automatic bilge pumps
and there is a pageful of 12 volt ones.
Next hit was
http://online-pumpshop.com/xcart/catalog/Low-voltage-electrical-p-1-c-11.html
portside II
  • tugs at rest
Re: bilge pumps
« Reply #5 on: January 07, 2009, 12:19:41 am »
why not try the pumps the ic boys use to refuel , i have one in my tug and it works for me (a bit slow but it works) .i also have a gaupner 12v pump ,both of them are the gear type and are self priming , one word of warning if your bilges are as dirty as mine fit an in-line filter as little bit's can break your pump gears , i have found out the hard way  O0.
daz
iDENTITi
Re: bilge pumps
« Reply #6 on: July 07, 2009, 09:43:12 pm »
I'd say go with the graupner pumps.  They're availiable on http://www.cornwallmodelboats.com.
