Author Topic: weight  (Read 7169 times)
Re: weight
« Reply #25 on: January 02, 2009, 02:07:53 pm »
On the other hand one has to wonder why some people will build model narrowboats and then operate them at speeds that would put a small budgie into orbit.
Barry M
Sticky thumb (ugh) or the Captain wants to water ski  {-) {-)
Ghost in the shell
  • Go Nuclear! you'll love it
Re: weight
« Reply #26 on: January 02, 2009, 02:37:06 pm »
In my opinion, though chances are, that I am probably very wrong, At a scale speed, a ship like Nord Icelandia, at her scale, she should just be developing a bow wave, rather than having her anchors swept under.  maximum speed for a vessel like her would be around 10 to 15 knots, which would be somewhere around 20km/h, and she wouldn't put a 6 foot wave on her bow.
I have tried to set her EPA up so that at full speed she is at scale full speed
"xxxxx" the tree huggers, GO NUCLEAR
Re: weight
« Reply #27 on: January 02, 2009, 03:09:36 pm »
There is indeed a calculation for speed but most people feel that a scale boat doing scale speed doesn't look right or give the correct wave formation.
Why?  too slow?
A lot of people think that scale speed is the speed of the original divided by the scale, when it should be the original speed divided by the square root of the scale.  When your scale boat is producing a believable wave pattern, this is the speed it is doing.  Incidentally, the power required to do this is closely related to dividing the original's power (converted to watts) by the cube of the scale.  Because inefficiencies in a model are greater, you usually need to add a considerable percentage, but it gets you into the right area.
Ghost in the shell
Re: weight
« Reply #28 on: January 02, 2009, 03:27:10 pm »
based on a 1/87th scale, 20km/h max speed.
scale speed using sq/rt gives 4.5km/h, which would be comfortable walking pace at just over 2.3/4 mph
scale speed using scale of speed (20km/h divided by 87) 0.22km/h, 0.13mph
to put that into perspective,
at 220m/hr (722ft/hr) she would take over 4 hours to cover 1 kilometer, and probably 9 hours to cover 1 mile! even nasa's crawler that carries the space shuttle from the Vehicle assembly building to the launch pad would be faster CARRYING THE SHUTTLE, and that little baby weights in at 6,000,000lbs (2,721 tonnes!) and can do 1.6km/h.
imagine taking 5 hours to walk the length of southport pier.
Tester
Re: weight
« Reply #29 on: January 02, 2009, 03:58:09 pm »
Just a quick point but isn't the scale speed of 20 kph at 1:87 around 2.15 kph ie 20 / 9.32 (square root of the scale) which is around 1.5 mph.
Or have i got the wrong end of the stick  {:-{ {:-{
Re: weight
« Reply #30 on: January 03, 2009, 10:16:56 am »
Tester, you have the right end of the stick.  Hang on to it.
TCC
Re: weight
« Reply #31 on: January 03, 2009, 02:44:00 pm »
Barry M
Like this ->
http://uk.youtube.com/watch?v=lBoPmaRl4q8
 ok2
Someone should show this guy the speed calculation. :-)
Ghost in the shell
Re: weight
« Reply #32 on: January 03, 2009, 02:54:01 pm »
thats a tad quick for a DD
catengineman
Re: weight
« Reply #33 on: January 03, 2009, 05:06:08 pm »
Scare the pants off any ennemy  :-))
having that running at you full tilt you would worry that the reactions of the helmsman were razor sharp  O0
TCC
Re: weight
« Reply #34 on: January 03, 2009, 07:19:38 pm »
It's the only model of a destroyer I've ever seen that leans into curves like a motorbike.
catengineman
Re: weight
« Reply #35 on: January 03, 2009, 07:22:48 pm »
Helps keep the coffee in the cup while on the bridge  :D
Cookie is happy as well  :-))
Bryan Young
Re: weight
« Reply #36 on: January 10, 2009, 06:13:20 pm »
I could be wrong here (again), but if you really want to get a scale speed then consider the following:-
No mathematics required. And this is all hypothetical:-
If a 500ft long ship was to take 50 seconds to travel its own length then wouldn't a 1:50th model of the same ship take 10 seconds to cover the distance? I'm sure somebody will point out the error of my thinking!.BY.
Notes from a simple seaman
Reade Models
Re: weight
« Reply #37 on: January 10, 2009, 06:22:48 pm »
What!  500 feet in 10 seconds - that's going some! {-) {-)
Malc
Re: weight
« Reply #38 on: January 11, 2009, 11:30:47 am »
The 1:10 model would be 50ft long.  (Big shed needed). The model speed would be based on the square root of the scale, so 1:10 equates to 1:3.16 for the model, original speed is 6.8 mph,  model speed is 2.16 mph, or 3.16 ft/sec, which works out at 15.8sec to cover 50 ft.
For your crew, time is passing rather faster than it is for us, based on the same rules.  Sorry about the maths, but its maths and not magic.
Bryan Young
Re: weight
« Reply #39 on: January 11, 2009, 06:54:24 pm »
I just knew it! But at least I was working on the same lines. Anyway, rather than get involved with semantics, I normally drive model ships at a slow(ish) walking pace. Looks OK. We have one guy in the club who drives a Liberty ship (10 knots real speed) at a scale speed of around 100mph. And he doesn't give a rats....he also has the anchors draped over the bulwarks. Oh well. Win some and lose some. BY.
