In a similar hull, same type of motor, same battery, larger prop, short run times and a hot motor (and a molten fuse holder, but thats another subject).
Malcolm,
Now that is intriguing, because I too experienced the exact same on two identical hulls. Both had identical motors, identical batteries and ESCs, the same propshafts, same props', yet one of them would always melt the fuse holder after a few minutes runtime. Even after swapping out parts from each hull, the problem would always persist. Out of sheer desperation I even swapped out each propshaft, in case one was binding. But that same fault was always there.
I have never been able to identify the root cause.
Did you finally nail the problem? If so, could you kindly throw some light this way?
