PMK,
So is the original "bad" set now in the good hull and operating correctly?
Bobbi: You'll have to excuse Mr. Calder's cynicism, but yes, that is exactly how it is.
I'm not trying to send you all round the houses, or even looking for answers. I've tried just about every which way - and more. The fault is just as baffling for me as it is for everyone else.
Me a cynic.....guilty as charged but "Bobbi" already knows why I'm that way.
PMK,I credited you with by thinking you had the experience and electronic knowledge to stop arsing about and sort out the problem logically.If the problem is overcurrent then ammeter tests go straight to the heart of the matter so if you stuck with them you could not argue with the readings.
I borrowed a single knuckle coupling out a fibreglass boat and when I went back to it after a year the prop shaft and motor were one eighth inch misaligned.The same thing happened to a ply skinned boat.
Never used a 2-knuckle coupling?
The chart is completely and utterly "to pot" :- Power is Torque x Rotational speed.
The chart is on a page where Johnsonmotor try to highlight that you can characterise and compare DC motors with four key data figures:-No Load Speed--No Load Current-- Stall Torque--Stall Current
If you leave out just one of those figures and use meaningless terms like
torquey and
low drain you can shift palletloads of useless motors at 80% markup to poor saps who have no comeback.
Back to the chart......Maxpower should coincide with 1/2 no-load rpm and ~ 45% efficiency.It doesn't happen on that chart as the power curve is out of scale.
Sandy Calder
