Author Topic: Frequency Identification  (Read 2506 times)
sea.mariner
« on: January 12, 2009, 09:53:55 am »
As I now have two boats ready to test on the local water, I will be using my new 40mhz FM radio gear, both boats have the same CH51 (40.675mhz) and the Xtal is coloured Blue. What do I have to display on the end of my transmitter antenna (apart from blue ribbon) i.e. something to show I am on 40MHZ FM rather than 27mhz ?? Cheers, Dan.
barriew
Re: Frequency Identification
« Reply #1 on: January 12, 2009, 10:04:17 am »
Hi Seaspray - you don't display a blue ribbon.  You display a ribbon with the frequency - last three digits - in white on a green background. Coloured flags are for 27Mhz.
Barrie
« Reply #2 on: January 12, 2009, 10:17:53 am »
Hi Sea Mariner
This topic came up a while back.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=2188.0
There are some suggested ways of making flags in here.
« Reply #3 on: January 12, 2009, 10:29:26 am »
Hi sea.mariner
You need to display your frequency in either white or black lettering on a green background.
I printed mine on the PC then laminated them, punched a hole in one end and threaded string through hole and then tied to the antenna :-))
