Author Topic: planking do you make your own?  (Read 9632 times)
walrus
Re: planking do you make your own?
« Reply #25 on: July 03, 2009, 06:06:57 PM »
Use the widest blade your machine will take ,make sure the top and lower guides are set correctly and let the saw do the wor
 you can improve the cut by carefully trimming the odd high tooth with an old oilstone
MCR
« Reply #26 on: July 03, 2009, 06:31:40 PM »
A fellow club member uses a router to produce his planking the trick is in using feather boards made from MDF and a sacrificial fence.
The planks are spot on.
MCR
« Reply #27 on: July 03, 2009, 06:42:23 PM »
This is the a saw that I use very impressed.
« Reply #28 on: July 03, 2009, 07:00:13 PM »
I hope he wears a mask when he's routing MDF.
MCR
« Reply #29 on: July 03, 2009, 07:02:37 PM »
No the feather boards are made from MDF they hold the wood in position as it is passed through the router.
portside II
  • tugs at rest
« Reply #30 on: July 05, 2009, 03:15:15 PM »
Just a thought with all this planking cutting , what do you think about using a tool i saw on the tv the other night ,exact saw.
http://www.jmldirect.com/product.asp?pf_id=E2299&utm_source=Yahoo&utm_medium=PPC&utm_term=exact_saw&utm_campaign=yahoo_JML_Direct&changecurrency=GBP
this may be a mechanical version of the balsa strip cutter.
http://balsamart.co.uk/store/index.php?main_page=product_info&cPath=138_151&products_id=2036&zenid=0965a2ce1e8cd8516b025c7d84075a3b .
daz
I like to build my boats to play with, not to just look pretty,so they dont !
