At the moment a 32 inch lifeboat, which we use is powered by
2 x7.2v 3000mah batteries wired in parallel and connected to a 550 mtroniks motor, on each shaft, so there are a total of 4 batteries to charge up
As these only last about 20 minutes, Im wondering what other options we could consider.
The motors are rated for up to 12v and have built in fans, but I was thinking about connecting a 6v 12amp lead acid to each shaft and respective speed controller in place of them.
Obviously power would be down, but weight would be similar and longevity should increase.
Is this the route to go, and should I be looking to change the prop size as well - if so what should I be looking for
Any guidance would be great
cheers
