I hope I am safe in assuming you have little knowledge of steam plant in answering these questions .
When you get your steam plant, it is essential to understand how to run it safely, they are lethal in the wrong hands. Talk to a club member who already has one.
I suppose in theory you could use any steam plant to power a boat, but the size of the boat, and the prop, will dictate the steam plant size.
You need to be aware that the power output of an engine is dictated completely by the boiler capacity, you can have a big powerful engine, but it will only produce the power if the boiler can steam fast enough.
As far as boiler certs are concerned, you need one renewed every 2 years if you are going to sail it in public areas, this is for insurance reasons as well. There is however an exception to this, if the boiler capacity is less than 1.5 bar-litres then no test certificate is required. This value is calculated from the total internal water volume (in litres) multiplied by the working pressure (in bar).
However, it is good pracise and for your own peace of mind to get any boiler checked regularly. Any boiler purchased new from a manufacturer should come with a test certificate indicating a hydraulic test to twice working pressure.
The safety valve should be tested annually against a proper calibrated pressure gauge.
I got this information from a booklet on boiler testing issued by federation of model engineering societies.
As for the choice of steam plant, as I said above, the size of the boat will dictate the size of plant, but the type eg, oscillating engine or vertical engine will depend more or less on your preference. Oscillators are cheaper, verticles look nicer!
The design of boiler, vertical or horizontal, will depend on the type of boat its going in and the space available.
here are a few links for your perusal!
http://www.stuartmodels.com/http://www.acs-engineering.co.uk/index.htmhttp://www.modelsteamenginesuk.com/boilers.asphttps://vault1.secured-url.com/reeves2000/shop_home.asphttp://www.pollymodelengineering.co.uk/sections/bruce-engineering/index.asphttp://www.steamech.com/marine-engine-model.htmhttp://66.249.93.104/translate_c?hl=en&u=http://fabrice.bretagne.club.fr/Page%2520d%27accueil.htm&prev=/search%3Fq%3Dfabrice.bretagne.club.fr%26hl%3Den%26lr%3D%26sa%3DGI hope i have been helpful, any questions, ask away.
good luck
